Results 1 to 25 of 36
Thread: What are you V8 guys swapping into an E36 doing for fuel pumps?
    Aug 2009
    Metro DC
    79 323i, 94 325is, 13 M3
    I'm running a Ford 5.0/302 with stock heads in my E36 now, and the BMW stock fuel pump is fine for the limited horsepower that comes with stock heads.
    This winter it's getting the top end upgrade, and I'm wondering if I need a new fuel pump to keep up. I cannot find, for the life of me, an LPH figure for the stock E36 OBD1 pump. Or the OBDII pump for that matter.
    Have other E36 folks needed a new pump with the higher HP LS motors, or an upgraded Ford small block? Could you please note also, whether your chassis was OBD1 or OBD2, since the OBD1s got a weaker pump.
    If God meant for man to motor-swap LS engines into track cars, He wouldn't have created Corvettes.
    Aug 2008
    Houston, Tx.
    '10 X5, '98 M3 - 302
    https://www.bimmerforums.com/forum/s...328i-fuel-pump
    Above you can see what the stock system is running. Below in the link there's a description of what you will need. Hope this helps.
    I have gt40p heads, e303 cam, stock intake, full exhaust, bbk 75mm throttle body, sct chip and running a Mustang oem fuel filter with the stock e36 pump.
    https://www.stangnet.com/mustang-for...91-5-0.856821/
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    I think most people making 400ish would run a walbro 255. Up to 600-700hp a walbro 450
    Mar 2013
    Lloydminster, Canada
    1992 BMW 325i
    I have an Aeromotive 340 in my tank. Fit in the OEM sending unit fairly well. Rated at 320 lph at 50 psi when supplied with 13.5 volts.
    I had an external walbro fuel pump in my last car. It was loud enough that I wanted an in tank solution for this car. Can't even hear this pump running when the engine fires up.
    Sent from my SM-G935W8 using Tapatalk
    Aug 2015
    dallas
    1993 325is
    Walbro 255.
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Yeah I would mount a walbro in the tank. External is annoying. I would not be surprised if that aeromotive pump was made by walbro or Bosch.
    Aug 2009
    Metro DC
    Thanks guys. I see a new fuel pump in my future, and as long as I'm going to the trouble it might as well be a Walbro 255, which I have used on another motor swap car already. Unless I find a screaming deal on a 155.
    Did you guys that installed the 255 use the stock wiring, it's what, 16 gauge? Or did the current draw call for heavying it up.
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Quote Originally Posted by JBasham View Post
    Wiring is pretty good factory i hear. Don't think many people upgrade.
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    http://walbrofuelpumps.com/255lph-wa...fuel-pump.html
    for the 76$ i would just get the 255. watch out for knock offs
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Very good info-thanks for posting!
    Aug 2008
    Houston, Tx.
    For some reason I thought they were more expensive. Gonna look into this for sure
    Mar 2013
    1992 BMW 325i
    I wouldn't doubt that most of the common electric fuel pumps are all made by 3 or 4 companies, but that doesn't mean they have the same parts. There are multiple reviews and tests online comparing pumps.
    I did increase my fuel pump wire size. I didn't like the idea of drawing constantly well over 10 amps with the OEM harness.
    http://realstreetperformance.com/Fue...ison-Test.html
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    interesting test, that aeromotive performs well
    i would like to see a Walbro 450 in that comparison
    Mar 2013
    1992 BMW 325i
    Quote Originally Posted by fallguy View Post
    The only tests I found online with that pump were done by walbro at 13.5 volts. From what I seen earlier most fuel pumps are tested at 13.2 volts... so they skewed the flow numbers a bit in their favor but it's still 405 lph, 16 amps at 50 psi . Definitely more flow than the Aeromotive unit.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    If you have a trunk mounted battery or need more than a 255, use the stock wires to power and ground a relay. Run a new lead from the battery to the relay and pump and use a local ground.
    Aug 2009
    Metro DC
    Based on that article's tests, I doubt I will be pulling 7.5 amps, but I think the stock pump only pulls maybe 5 amps. I'll check the wire gauge and see where it is, because I think the relay is good for like 40 amps.
    I'm not crazy about using the stock wiring as relay control. It's a track car, so if I pull the kill switch, I don't want the fuel pump to keep spinning off battery power. There's not much chance of that happening since the kill switch would shut off the relay control power, but it still makes me a little nervous leaving the pump with a second path.
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    https://www.bimmerforums.com/forum/s...ro-450-install
    thoughts are the wiring is good for 20AMPS, just switch the fuse....
    Mar 2004
    USA
    96 328is 6.0L
    Using BMW factory pump on mostly trackable LS2. Works just fine.
    S54 Roady, LS1 & LS2 E36
    I have stock E36 pump on stock LS2. Seems fine to me.
    Jun 2005
    New England
    A good stock pump will do about 400 rwhp, but I would leave a substantial margin. Changing to a real, not fake, Walbro 255 is probably smart. It's cheaper than a voltage booster to extend the range of a stock pump.
    Aug 2009
    Metro DC
    Quote Originally Posted by bimerok View Post
    Impressive, that motor runs at a higher PSI than stock and I think the pumps GM used were a couple hundred LPH.
    Aug 2009
    Metro DC
    That sounds about right, but check my math:
    The ETM for my model E36 says the wire is 1.5mm, which is right between 14 and 16 gauge? Pick your favorite automotive wiring gauge table; mine says assuming I have about 10 feet of wire to the pump, I should keep it down to 25 amps, but if it's 15 feet, I should keep it down to 15 amps?
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Cool
    im going to jam in a 20amp and a walbro 450 and "i'm just going to send it"
    Jul 2013
    FL Gulf Coast
    E36 - 1998 328iS - LS2
    ... Changing to a real, not fake, Walbro 255 is probably smart....
    How are you guys ensuring you're getting a real Walbro?
    When I'm in China, spotting fakes is easy (it's all fake). And, it's right in the name of the market! (that is a real map entry)
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    You can actually buy directly from walbro now. They did this because of all the fakes. But if you buy from a larger outfit like summit racing you will be fine.
  1. M62 swap into an e36?
    By alpine318is in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 11-25-2009, 06:58 PM
  2. 83 633csi drivetrain/motor swap into an E36
    By bilstein325i in forum 1991 - 1999 (E36)
    Last Post: 01-29-2007, 07:03 PM
  3. What are these wheels? Will they fit an e36?
    By e36uk in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 12-25-2005, 03:57 PM
  4. What are you Ti guys paying for insurance?
    By einhander in forum 1991 - 1999 (E36)
    Last Post: 08-04-2004, 06:24 PM
