Results 1 to 4 of 4
Thread: S54 rod bolt torque
    Jul 2010
    KC, Mo
    04 M3, 02 E39, 01 46 M3T
    S54 rod bolt torque
    I have the most current BMW service bulletin about S54 rod bolts. Mine is an April 2002 build. The Service bulletin specifically calls for RE-USING the existing rod bolts (on S54s built before mid December 2002) and even emphasises that each MUST go back exactly where it came from.
    Who can confirm this?
    Jul 2010
    KC, Mo
    Paging Randy Forbes !!
    SW Florida
    99-01 M Cpe & Rdts, X5M
    And to think, those were supposed to be the better updated bearing shells (so yes, they'd already been replaced; any idea how many miles ago?).
    Jul 2010
    KC, Mo
    Quote Originally Posted by Randy Forbes View Post
    Unknown miles since update. Total miles on the car is about 130K. I installed the WPC treated bearings. Per our conversation, the original bolts are in place. The compression tests were very good, so I did not chase rings. Of course, at $1200+, that was a relief. Based on the condition of the bores, the very dry exhaust post and muffler tips, and the dry piston tops, I am confident that they are still in good shape.
    I am sure glad I did this on an engine stand !!! It must be a real treat IN the car. Some things I noticed are 1) the inconsistent pull needed to break loose the rod bolts, and 2) the odd and inconsistent wear patterns. I have pulled down dozens of M20, S&M 50/52s, and a couple of M54s. Never seen the odd locations and inconsistent patterns of wear like that.
  1. E46 S54 ROD BOLTS Set of 12 11247834310
    By stratosphere in forum Engines, Performance Parts & Software
    Last Post: 12-20-2011, 09:15 PM
  2. Rod Bolt Torque Spec! URGENT!
    By kineticimpulse in forum 1994 - 1999 Euro M3 (E36)
    Last Post: 06-08-2010, 11:16 PM
  3. BMW 635CSi M30 Engine connecting rod bolt torque specification
    By FeltonBarch in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-25-2008, 11:27 PM
  4. Rod bolt torque spec?
    By JeremyS in forum 1992 - 1999 M3 (E36)
    Last Post: 07-23-2004, 09:45 PM
  5. Rod Bolts - Torque To Yield? and bearing question...
    By erikras in forum 1983 - 1991 (E30)
    Last Post: 03-18-2004, 05:02 PM
