Results 1 to 2 of 2
    Dec 2010
    New York
    2001 BMW X5
    Exclamation Cranks, wont starts, please help!
    Hi folks! Need your help.
    So I came back from the gym a few weeks ago, parked the car in the driveway and all was good.
    Next morning tried to start it but it would not start, only cranked.
    Scanned for codes, got a P1349, misfire in cylinder 4.
    So I replaced all of the spark plugs (with NGK) and also installed new Bremi ignition coils (with boots).
    Still would not start.
    So then I did some research and after some diagnostic tests for fuel pump, I installed a new fuel pump (Delphi).
    My neighbor was around and suggested I floor the gas pedal and try to start the car.
    Did that and it cranked and turned on! But after letting it idle for about 6/7 mins, it just shut off on its own.
    Now back to cranking and not starting.
    In some tries, it "kind of" starts and then turns off after a few seconds.
    Tried to scan for codes but nothing.
    Any help would be very much appreciated.
    The following lights are on since this start problem:
    Service Engine Soon light, the battery light, and an oil lamp looking light.
    There's about a quarter tank of fuel in the car. Oil change was done a while ago, although not recently.
    Side note: I replaced the water pump, water pump pulley, fan clutch, and did a coolant flush about a month ago. The car was running fine and there are no leaks or coolant problems in sight.
    Info on car:
    2001 BMW X5 (E53)
    130,000K miles
    Thanks in advance!
    Bikram
    Oct 2017
    Castlerock , Co.
    2009 bmw x5 4.8
    Look at my post. Try a new fuel relay.
  1. 95 bmw 840ci wont crank wont start please help
    By Dukes95bmw840ci in forum 8 Series (E31)
    Last Post: 08-05-2016, 10:05 PM
  2. 93 325is cranks but wont start. Please help!
    By kingflip in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-07-2014, 10:08 PM
  3. Car cranks but wont start, please help!
    By beamer420 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-21-2012, 07:37 PM
  4. IT WONT START... please help me ;_;
    By Sieghardt in forum 1992 - 1999 M3 (E36)
    Last Post: 04-14-2006, 03:42 AM
  5. Car wont Start !!! Please Help
    By bandit1911 in forum 1991 - 1999 (E36)
    Last Post: 01-31-2003, 10:27 AM
