Results 1 to 23 of 23
Thread: Uber's 740i Build
    May 2005
    South Africa
    '94 540i/6, '82 628CSi
    Uber's 740i Build
    Took this 740 over from my brother.
    Little history:
    He bought a 740i with a bad body. Had been hit in the rear and the repairs done were quite bad. The whole car was resprayed in a dark grey and used by a funeral parlour, but it drove great.
    A little while later he found the below 740i with a buggered engine but a much better body. We decided to swap engines etc and make one good car.
    So...with the help of my father, we took the engine out
    Front engine is buggered. We suspect it dropped a valve. Rear engine is perfect.
    The previous owner managed to fry the wiring in the fuse box. Replaced the whole engine harness and most of the body harness.
    Put some different wheels on:
    Had found this Hartge kit quite some time ago. Did a little test fitting. The kit came off a long wheel base so will have to trim the side skirts:
    The interior has been like this for ages:
    Stripped out the rest of the carpet. Need to fix the heater core and some other stuff. Will be putting in a grey carpet and dye everything else black:
    Started by stripping the grey dash and dying it black:
    And that's where I'm at...work continues.
    E34 540i/6 Sedan | E34 540i/6 Touring | E34 520i Sedan | E32 740iA | E24 635CSi | E24 628CSi
    Mar 2016
    Lincoln, NE
    91 735iL
    Nice work!
    May 2005
    South Africa
    More progress:
    Installed a grey carpet and put the dashboard in:
    Dyed some more stuff black:
    Installed:
    Installed an engine:
    Epic 4x4 mode:
    "Tearing" down the engine for a good cleaning:
    Engine ready to go in:
    More interior bits done. Slight colour difference in the carpet...will eventually dye it black:
    Engine finally in:
    Installing an autofail:
    Dying some bits for sport seats:
    Installed:
    Doesn't look too bad. Still need to have the bodykit sprayed and do plan to lower it eventually:
    Managed to find some stuff to start the 6 speed manual swap as well:
    Mar 2018
    Asia
    1992 E32 M60 V8 RHD
    i wish i have lots of time and at least complete needed tools to remove an engine
    Apr 2013
    United States
    '91 M5, '13 E92, '89 E32
    those black sport seats look great...nice work all around!
    1989 750iL schwarz/schwarz
    1991 M5 schwarz/silbergrau
    2013 328i coupe diamondschwarz/caramel
    2003 525iT orient blue/tan
    1990 535i/5 schwarz/schwarz
    Oct 2007
    Boca Raton, Florida
    89'750iL,98'740iL,00'M5
    Looks really great, how is the dye holding up on the consoles? Did you do the doors too?
    BMW 7er Website www.7er.com
    1989 BMW 735i Schwarz (sadly, sold) // 1989 BMW 750iL Cirrusblau Metallic // 1998 BMW 740iL Oxfordgrün Metallic // 2000 M5 Carbon Schwarz ///
    May 2005
    South Africa
    Thanks guys.
    @SergeBMW - Dye is holding up really well...no problems at all. Door cards have been done as well.
    warwick RI
    E30/E32/F25
    Looks nice man ! Nice e34 too !
    Me E30 87/ 325i + F25 12/ M-Sport + E32 94/ 740i
    G/F’s E34 92/ 525iT + F48 18/ X1
    Dec 2008
    manning, SC
    93 e32
    What wheels are those in the last pics? Looks great!
    May 2005
    South Africa
    Thanks again, good sirs.
    Wheels in the last pic are Rondell 58
    May 2005
    South Africa
    Red face
    Some updates:
    Dyed the carpet black:
    Swapped to some E34 mirrors:
    Currently at the panel beaters getting the Hartge kit painted:
    May 2005
    South Africa
    And the Hartge kit is fitted.
    Some aligning and stuff to be put back still.
    warwick RI
    E30/E32/F25
    Oh man ! Looking really good ! I’m drooling
    USA
    e34 540ia/e32 740il
    Wow! That is some awesome work! The sports seats look so good in an e32.
    warwick RI
    E30/E32/F25
    Uber what are you doing about the little black rubbers on bottoms of doors ? I’ve wondered about using e34 ones to color match skirts
    Nov 2012
    Los Angeles, California
    1991 320i M-Tech II
    Awesome build, very well done!
    My YouTube channel: https://www.youtube.com/channel/UC7l...rJvxZHr_00nuhA
    Current cars: 1990 Mercedes-Benz 300E, 1991 BMW 320i M-Tech II, 1991 Mitsubish Galant AMG Type II, 1992 Nissan Figaro, 1993 Toyota Chaser Tourer V
    May 2005
    South Africa
    Thanks again dudes
    @e30luv318i - Funny you mention that. For now I've put the black strips back. Tried a spare set of E34 door caps but they seem to be about 1cm short, either side of the door.
    Put the chrome bumper trim back including some headlight washers. Also added a rear licence plate holder thingy.
    warwick RI
    E30/E32/F25
    Looks so good !!!!!!!
    May 2005
    South Africa
    @e30luv318i - Thank you again good sir
    A little bit of lowering
    Nov 2005
    Quebec Canada
    92 735iL (12/1991)
    That looks excellent! What did you use to lower it?
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    May 2005
    South Africa
    @Cactuar - had them compressed for now. It drives surprisingly well. Do plan to eventually get some H&Rs
    @ Moroza - Thank you sir. I used RIT multipurpose dye for the carpet, plush leather dye for the seats and duplicolour vinyl and fabric for the dashboard.
    moroza's Avatar
    BFE
    E34T
    Cars need maintenance, especially German cars, especially old ones. Their maintainers need maintenance, too. Maintenance budgets are finite, and when one is the custodian of what seems like half of the 20th-century BMWs in South Africa... with fairly high standards, at that... on top of full-time work with its own stress factors... on top of landlord issues... and on top of taking care of two (and a half?) human dependents... the maintenance budget gets stretched thin, and sooner or later, something has to give... ideally something other than one's skull, to the inertia of large rigid objects. Mr. Uber is alive and reasonably well, currently taking what seems to be a long-overdue and well-deserved mental health break of several days. Frankly, I'm impressed he's managed to get this far without one. I imagine he could use a kind word or two of moral support from anyone in the community. I imagine the rest of us, especially those with sizable fleets, could use a reminder of the importance of self-care. And if anyone has a shipping account, and/or significant experience with international shipping, with a company more reliable than UPS is proving to be, PM me please. Also requesting a PM from anybody with a lead on rear side window roller sunshades.
    (Hang in there, buddy)
  1. My 1998 750il & 2001 740I build thread
    By Jamespolow in forum 1995 - 2001 (E38)
    Last Post: 04-20-2016, 08:46 PM
  2. New here 1993 740i build-what am i getting my self into??
    By Nick4829 in forum 1988 - 1994 (E32)
    Last Post: 08-31-2015, 12:12 PM
  3. My 95 740i build/maintenance thread
    By aythatblackguy in forum 1995 - 2001 (E38)
    Last Post: 10-16-2013, 08:37 AM
  4. SC 740i build
    By BMW5868 in forum Forced Induction
    Last Post: 03-04-2009, 01:05 PM
  5. help me build a nice sound system for 95 740i
    By kickster in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-16-2008, 11:08 AM
