Results 1 to 7 of 7
Thread: Vibration under acceleration.
    Feb 2004
    CT
    1989 325i, Mini Cooper S
    Hi, I have a 2005 x3 3.0. I've had a vibration start when giving it gas. Speed, gear, warm or cold doesn't seem to matter. Sometimes I can seem to feel it more, but always present when giving it gas (accelerating). Let off the gas pedal and vibration goes away. So seems to be something that takes load.
    I bought new tires and had them balanced, no change. (Needed tires anyway).
    Took out the center driveshaft support and flex disc. Both seemed in great shape, not soft very little flex.
    Checked the vacuum line for the flap on the exhaust, connected. But line did seem a little dry.
    Checked front cv boots, didn't see any cracks or splits that would let out any grease.
    Not sure if it would have anything to do with it, but ordered some transfer case fluid so that will be changed.
    Any other ideas or things I could check?
    Feb 2004
    CT
    Still no luck on solving my issue.
    Apr 2016
    Philadelphia
    1997 m3
    Check motor/trans mounts. Depending on the age of your vehicle, it might be time for a change.
    Feb 2004
    CT
    I'll take a look thanks. Would that feel different if I was parked and gave it gas? If I do or don't get the same vibration. If it was mounts I would think it would be present not moving giving it gas.
    Apr 2009
    Raleigh, NC
    2005 BMW X3
    I'll bet its your transfer case. Try unplugging the actuator to see if that makes the vibration go away.
    I had a very similar issue on my E91 xdrive, I was able to fix it by changing the fluid. When the fluid wears out, the clutches stick and slip, causing a chatter that you feel during acceleration.
    Jun 2017
    North New Jersey
    1999 E36 M3, 2004 E83
    Check your motor mounts. I have the same issue under acceleration very large vibration felt in left front of vehicle and in steering wheel. I inspected and found my left front motor mount leaking and under hard accel the motor flexes and the left front axle hits the steering column.
    Cave Creek, AZ
    1993 850ci 2001 M5 / Z3M
    how many miles on the car?
    Regards,
    Brian
    Cave Creek, AZ
  1. Help! Hard Vibration under acceleration, not driveshaft related.
    By m3mobbin in forum 1992 - 1999 M3 (E36)
    Last Post: 10-26-2010, 04:31 PM
  2. Heavy vibration under acceleration, RPMs so low car stalls while driving/stopping
    By tehspamninja in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-16-2010, 06:59 PM
  3. Loud vibration under acceleration
    By 96alpine328i in forum 1991 - 1999 (E36)
    Last Post: 02-06-2008, 11:55 PM
  4. E30 Vibration under acceleration
    By Numereins in forum Georgia sponsored by Harrison Motorsports
    Last Post: 12-20-2007, 11:29 AM
  5. Bad Vibration under Acceleration, not guibo, not center bearing
    By Mjollnir in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-14-2005, 01:17 PM
