Page 3 of 3 FirstFirst 123
Results 51 to 68 of 68
Thread: 2.8 Roadster possible intake leak, symptoms?
  1. #51
    Jun 2016
    Odessa, TX
    2000 BMW Z3 2.8 Roadster
    Is ZA its own specific market *ONLY*, or part of the European region of BMW's market? Realoem doesn't let me view any engine parts if I enter the 2.8L for ZA with 9/98 production month, which is the closest I could get to a '99 year model Z3 Roady.
    My dad's '09 Chevy Traverse has a stretched timing chain. Won't throw a DTC or MIL until you get it into just the right conditions (probably fully advanced or retarded timing with the VVT). I don't know about BMW, as my timing chain still isn't worn enough to get into abnormal readings and my cam sensor / circuit isn't damaged. BMW may have different parameters.
    You should listen to Randy rf, he knows what he's talking about.
  2. #52
    Jul 2016
    Vanderbijlpark, ZA
    '99 Z3 2.8 Roadster
    First post: That's why I asked initially. You're right, that's where I saw it. The printout said Delphi, if that helps.
    Second post: To be honest, I don't know how the adapter plate will look. Mine appears to be like in this thread (I haven't checked now as it's already past 10 at night, but I've done enough in that area):
    https://www.bimmerforums.com/forum/s...-Help-With-Fix
    I didn't see the third post. Anyway, as far as I know it's at least very close to EU. And it is a 9/98 car, so you were actually spot-on.
    And the car has 180k km on the clock (hopefully not far off, I don't trust those numbers anyway), so I doubt it will have a bad chain.
    1999 BMW Z3 2.8 Roadster - show project
    1970 VW 411L Auto - show/restoration project (sold)
    1982 BMW 518i E12/8 - stolen
    1987 Mazda 323 1.5 SL - daily driver, backup show car
  3. #53
    Texas
    '02 Z3, '09 Mini
    My 2 cents, but that black box on the right side of the intake manifold looks like the DISA valve unit on the M54. Did M52TU have DISA?
    Also, it's interesting how things are moved around from the driver-on-the-left-side setup of US cars. Brake reservoir switched sides to the enclosure for the DME (looks like perfect fit, but probably wouldn't want to spill brake fluid in there), washer fluid went from bottom left side of picture to the place where brakes are on US cars, and something (?) is where the washer fluid would be on US cars. Excuse my ignorance but what is that cylindrical thing in the front left of the picture (by strut tower)? Secondary air pump (which is in the DME enclosure on US cars)? Anyway interesting.
  4. #54
    Jul 2016
    Vanderbijlpark, ZA
    '99 Z3 2.8 Roadster
    Quote Originally Posted by raubritter View Post
    Yep, the TU did get DISA. EDIT: If I'm not mistaken the M52TU had single DISA, and then double on the M54.
    So that box is the DME? I started wondering a couple days ago, but I wasn't sure.
    I don't know what that thing is either. It is on my list of things to find out, but not urgent.
  5. #55
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    The physical mounting is not the problem. The MS43 knows nothing about driving a 52TU MDK throttle unit, just as a MS42 knows nothing about driving the M54 EDK. The combination as described will not function at all. There is something really wrong here, and it isn't the scanner's report of the ID.
    Yes, both motors have a single disa valve. They appear the same from the outside, though they have different sized flappers.
    /.randy
  6. #56
    Jul 2016
    Vanderbijlpark, ZA
    '99 Z3 2.8 Roadster
    Could you elaborate then? I don't really get what exactly you mean by "will not function at all". What will the implications be, if it is indeed a MS43 with a M52TU throttle body? Keep in mind the car normally has a perfect idle (lately not always though), and while the bottom-end is almost always a problem (along with an overall "lazy" response meaning noticeable lag, rev hang, slow rev), the top-end is almost always great.
    I'll also ask the mechanic to check for any intake leaks, since I only replaced those two rubber pipes and more might be problematic.
    EDIT: Should I open the DME box tomorrow, and see what's in there?
  7. #57
    Dec 2007
    Great Dismal Swamp
    The two throttle system are electrically incompatible. The MDK is PWM magnetic induction controlled, the EDK is a true stepper motor system. Wiring one to the wrong DME will at a minimum set a bunch of codes and result in no throttle actuation, with a maximum of letting the magic smoke out.
    There is a label on the DME that will include programming info, engine. And VIN. It would be worth taking a look at it.
  8. #58
    Jun 2016
    Odessa, TX
    You can plug the last 7 of your VIN number into realoem.com and get your info off there, or plug it into one of the VIN decoders. I'm fairly sure that you at least have dual VANOS, so it can't be a ZA-specific market 2.8 if it is a 2.8.
    To look for a throttle cable without removing any components, I think you can look under your steering wheel at the top of the accelerator pedal. Assuming all M52tu vehicles still have a throttle cable as well as a form of drive by wire (the technical info Randy gave me suggests BMW didn't fully trust it, as it says the throttle cable is a backup for if the MDK failsafe mode). At the top of the accelerator pedal, my '00 2.8L (tu) has a sort of Z- or C-shaped ferrule at the end of the cable that hooks it into the accelerator pedal assembly. The M54 will have no cable there at all, just electrical connections and a spring.
  9. #59
    Jul 2016
    Vanderbijlpark, ZA
    '99 Z3 2.8 Roadster
    I had a look, but it seems I'll have to disconnect the DME before I can pull it out and check it. What's the correct procedure for this, considering that this is a sensitive computer, and how critical it is for the car to run?
    I did have to break the screws loose, which is odd. Unless the printout was for some reason wrong?
    And I checked at the pedal as well, it is indeed an old cable system.
  10. #60
    Jul 2016
    Vanderbijlpark, ZA
    '99 Z3 2.8 Roadster
    Oh, and I forgot to add this, but I did a VIN checkup before I bought the car.
    Manufacturer:
    BMW Germany
    Brand:
    BMW
    Model:
    Z3 E36 Z3 2.8
    Engine:
    M52
    Region/Plant:
    ECE
    Year:
    1998
    Maker BMW
    Name Z3 2.8
    Body color ATLANTABLAU METALLIC (306)
    Market E
    Production Date 28.09.1998
    Body Style родстер
    Steering Right
    Description Z3 E36
    Doors 2
    Transmission Manual
    Series code Z3
    Engine M52 (2800CC / 142kW)
    Vehicle ID (removed)
    Type CH32
    Drive RWD
    Interior color LEDER OREGON/SCHWARZ (Q2SW)
  11. #61
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
  12. #62
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Secondary air pump.
    Quote Originally Posted by rf900rkw View Post
    For e46 it's a common practice to swap wire throttle to cable throttle...
    Quote Originally Posted by JKuhn View Post
    Turn off the ignition, and good to go. Disconnection is straightforward - you have to pull some lever on connector to disconnect. Car will not run without ECU, so quite critical
    Additional probably non-oem looking metal plate between throttle body and intake manifold around 10-20mm thin. It's adaptor for different bolt holes patterns on throttle body and intake manifold. You can see shiny aluminium adapter plate here: https://a.d-cd.net/e1e1872s-960.jpg
    I tend to think so and that you have m52tu.
  13. #63
    Jul 2016
    Vanderbijlpark, ZA
    '99 Z3 2.8 Roadster
    So no need to disconnect the battery, and no need to pull a specific plug first?
    EDIT: I can't get the plugs out, and I don't want to mess with the wires too much (in case they decide to break off). I'll just leave it for now, and find out when the car goes in. It shouldn't cost much to just check the sticker on the DME...
  14. #64
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    For disconnecting ECU - no. You can disconnect the battery if you want for peace of mind.
  15. #65
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by deni2s View Post
    Ya, but to a purely mechanical throttle, not the m52tu dbw throttle. (It is very much a dbw in m52tu). And then you'd still have a ton of errors in the dme sending a lot of the routines in limp mode.
    BTW Not sure if there are any more benefits to changing from dbw throttle to mechanical throttle... For normal cars you lose cruise control and dsc, and gain limp mode unless very well tuned.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  16. #66
    Dec 2007
    Great Dismal Swamp
    Five connectors have to be unplugged. Do them in the order the harnesses lay out. Three have push tabs and pull out. Two have levers locked closed by a push tab. You can disconnect the battery if it will make you feel better, I never bother.
    /.randy
  17. #67
    Jul 2016
    Vanderbijlpark, ZA
    '99 Z3 2.8 Roadster
    UPDATE: I got the car back. There was a loose vacuum pipe, and the VANOS is now also done. It still doesn't run right, but the VANOS was on my list (now I know it's right), and the vacuum leak had to be done either way. So I guess the next step is to check the base (feel free to tell me if there's a better way to put it) cam timing.
    I also found out that the car does have the correct MS42, so that's the end of that mystery.
  18. #68
    Jul 2016
    Vanderbijlpark, ZA
    '99 Z3 2.8 Roadster
    I hoped this matter wouldn't go on this long, but it seems it did. Anyway, I'll create a troubleshooting thread for this matter, and link back here for reference. That way the thred title can be more appropriate, and I'll also sum it all up in the OP.
  1. Intake Manifold Leak Symptoms
    By dherna1588 in forum 1996 - 2003 (E39)
    Last Post: 11-04-2015, 09:25 PM
  2. Possible intake leak
    By wiberforce in forum 1988 - 1994 (E32)
    Last Post: 04-22-2014, 08:56 AM
  3. 2000 M roadster sprung coolent leak under intake maifold
    By dcroghan in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-13-2011, 05:40 PM
  4. Symptoms of an intake leak`
    By Nic01101011 in forum 1983 - 1991 (E30)
    Last Post: 04-26-2009, 07:03 PM
  5. Possible have a intake leak & sticking throttle.
    By Austin in forum 1991 - 1999 (E36)
    Last Post: 02-17-2003, 01:59 AM
