Can I use any E36 ODB2 DME? Or do I need a specific part # one?
'03 911 Turbo 6MT fun car
'18 Toyota Land Cruiser Daily driver/Ski Machine/Off Roader
'15 Cayenne Diesel Wife's DD
'17 KTM 690 "Adv" 2 wheeled Adventurer
It needs to have the same part number as the one you have. But you'll need to get the DME aligned with your EWS, otherwise the car won't start. But if you're like me & you no longer need EWS in your life, give this a look:
https://www.bimmerforums.com/forum/s...-99-E36-MS41-1
E36 328iS- Sold :(
E92 328i 6MT- Work In Progress
"If you have to fight the urge to look back at your car as you walk away, you bought the right car."
I got one that's the same part #. Shop will align the EWS for me. Can you have two dme's aligned? Or when you align a "new" one it forgets the other one?
As far as I know you can, since the EWS just needs to "see" the correct information from the DME (matching part #, VIN, and a "start signal").
E36 328iS- Sold :(
You can have both DME's recoded to match so that it works with the EWS system.
However for a track car you might want to think about doing EWS deletes to them for ease of convenience since the modules do go bad over time.
I had mine deleted at no extra cost through a company that specializes in this stuff when I had mine replaced (They also test and repair them). They can also do burble tunes, increased Rev Limit and all that jazz.
PM me if you you're interested.
I ended up not needing the dme, so now I have it as a spare. It might make sense to have ews deleted on both my dme's though. I wouldn't want to mess with the tune that's on my current dme. Can just the ews be removed?
