BMW of Bloomfield
Results 1 to 20 of 20
Thread: 1995 BMW M3 Turbo (600whp, Built Engine, GTX3852R, 210mm Diff, Coilovers, and More)
    Joliet, IL
    Out of Service
    Unfortunately, the time has come to sell my 1995 Turbo BMW M3. I have been consistently working 60-70hrs per week so I just don?t have the time to tinker any longer and it?s only a matter of time until I end up with a ticket ?. So, I am bailing on my plans of turning this 600whp 93 octane beast into a 850whp E85 Monster. The car is a 1995 BMW M3 Lux Coupe in Artic Silver with Black Interior. If the new owner would love to finish the build I had planned, they will have first dibs at any parts I had collected for the build. The car carries a clean title.
    Note: If not specifically noted, the maintenance/modifications were completed at 131k miles. The car currently sits with 151,240 miles
    Asking $13,999
    Engine
    • ~20,000 miles on a rebuilt BMW S52 engine.
    • 8:5.1 Wiseco pistons (Ceramic and Teflon coated)
    • 135mm Pauter rods w/ ARP 2k Rod Bolts
    • Cometic MLS head gasket OEM thickness
    • VAC Upgraded Oil Pump (Upgraded pump shaft, gear and bolt)
    • SS O ring'd block
    • ARP 2k Head Studs 10mm
    • Webb 536/546 Turbo Camshafts
    • Ferrea Stainless Intake and Exhaust Valves
    • Ferrea Double Valve Springs
    • OEM gaskets and chains
    • Vanos Rebuilt
    • M50 intake manifold
    • Retained all OBDII wiring, sensors and DME
    • S54 M3 3-row Radiator with Diesel fan clutch and new expansion tank
    • S54 M3 OEM Oil Filter Housing and Oil Cooler
    Technica Motorsports Stage 2 turbo kit Including the following
    • Technica OBDII Dyno tune for 60lb/hr injectors and Technica Blowthru MAF
    • SPA T3 Ceramic Coated Manifold
    • Garrett GTX3582R with T3 .82 A/R Ceramic Coated Turbine Housing
    • Synapse Synchronic Blow off Valve
    • Tial MV-R Wastegate with separate wastegate dump with small muffler
    • 24x12x3 Intercooler
    • Intercooler bracket
    • Technica Motor mount
    • K&N Air filter
    • Technica Charge pipe kit.
    • Charge Pipe silicone and T-bolt clamps
    • All AN Water and Oil lines and fittings
    • Technical vacuum distribution block
    • 3.5" Stainless Steel Downpipe/Vibrant Cat/Midpipe to 3" Stainless Steel catback with Stainless Magnaflow muffler
    • Two Aeromotive 340LPH in tank fuel pumps with individually wired fuel pump relays and fuses
    • Aeromotive A1000 FPR w/ Aeromotive Gauge at 151k
    • OBD2 E36 Fuel Rail
    • Vibrant Crankcase Catch Can
    Drivetrain
    • Lower mileage ZF transmission installed
    • UUC Polyurethane Transmission Mounts
    • Southbend Stage 5 Clutch Installed at 150k
    • UUC EVO 3 Short Shifter
    • Rogue Engineering Weighted Selector Rod
    • CES E32 750il 210mm 3.15 LSD conversion and Black Powerflex Subframe bushings
    • Recently serviced driveshaft at 150k (New Guibo and Center Support Bearing)
    • New ABS Unit at 100K
    • New Clutch Master Cylinder
    • New Clutch Slave Cylinder
    Suspension/Steering
    • TRM E36 Coilovers
    • TRM Camber Plates
    • TRM Springs 670F 895R
    • Turner Motorsports Sway Bars 30mm/24mm
    • Adjustable Rear Lower Control Arms (Can’t recall brand, but look similar to SPC, but are silver)
    • Front control arms and bushings replaced at 95K
    • Z3 linear power steering rack
    • Tie rods replaced
    • Front wheels bearings replaced
    • New OEM Front Control Arms and OEM Bushings at 95K
    • Black Powerflex RTABs
    • 75mm Front / 90mm Rear Wheel Studs
    • ASA 17x9 Black center/polished lip with tires
    • Nitto NT-01 255/40-17 Rears (Will need replacement)
    • Fuzion ZRi 255/40-17 Fronts (lots of life left)
    Exterior
    • All OEM rust free panels and bumpers with paint in excellent shape considering the cars age
    • Bavtoys Depo Hella Style Ellipsoids
    • BTX-55 AC Power Slim HID
    • 5000k Mishimoto H1 bulbs
    • OEM Clear Taillights, Front Turn Signals and Side Markers
    • Black wide kidney grills
    • Carbon Fiber wrapped foglight deletes
    • New windshield at 131K
    Interior
    • Interior leather and components in great shape with the exception of the driver seat bolster and the door cards will need some minor adjustment if you a perfectionist (a few of the clips were broken when they were removed for the stereo install). Also, the sunroof needs to be recovered, but I had plans to replace it with a CF insert (not included in sale).
    • Viper Remote Alarm/Door Locks
    • UUC Motorwerks Dead Pedal
    • Leather Z gauge pod w/ VDO Oil pressure, Oil Temperature, and Water Temperature gauges installed in place of the OEM sunglass holder. Also gauges use remote senders
    • E46 Sport Steering Wheel (I think???)
    • VEI gauge with Boost/AFR integrated into the instrument cluster in place of the OEM MPG gauge w/ SM-AFR module in Glovebox
    • Innovate LM-2 Wideband AFR Installed in Glovebox
    • Greddy Profec II Boost controller
    • Kenwood KDU-BT362U Head Unit
    • Infinity component front speakers with Boston G3 subwoofer and Planet Audio amplifier.
    • M3 Floor Mats
    • Fully Functioning OBC with no burnt-out pixels
    • Fully Functioning A/C (stock fan replaced with SPAL Low profile pusher)
    • New OEM Battery at 120K
    Parts that are NOT included in the sale, but will be available at with first dibs to the buyer of the car
    • New E36 Twin Scroll Steedspeed Manifold w/ Turbo Smart Hypergate
    • RK Tunes E85 OBDII Tuning (115# injectors, MAF, and OBDII DME w/ 93 and E85 tunes)
    • Precision 6765 DBB Turbo w/ Two Exhaust Housing (TS 1.15 and TS 0.84) and lava blanket
    • New Felony Form Over Fenders
    • New Hard Motorsports V2 Over Fenders
    • New S2R Tuning Carbon Fiber Sunroof Delete
    • New Abrahams Motorsport E35 LTW Rear Wing
    • 18X9 ET32 / 18X10 ET32 AC Schnitzer 2 Piece Type 1 Wheels Powder Coated Black w/ Red Time Attack Stripe
    • E36 M3 UUC Twin Disk w/ Organic Discs (has 1000 miles on it)
    • E36 M3 Competition Clutch Twin Disc
    • Autopower 4 Point Roll Bar
    • Fully 3.5” SS Exhaust with vibrant performance resonator and black muffler (3.5” single outlet)
    • HPF 3.5” inlet to dual 3.5” outlet Titanium Exhuast Tip
    • Allstar Performance Fuel Filter
    • Radium Engineering
    • Kenne Bell boost a pump
    • Spare Walbro 450lph FST-R Fuel Surge Tank with Integrated FPR and Walbro 485lph installed
    • Spare AEM wideband gauge w/ oxygen sensor and AEM boost gauge
    • Spare UUC Evo 3 SSK with DSSR
    • Spare UUC Sway Barbarians
    • Spare Ground Control Coilovers Track/School Kit w/ Hybrid Camber/Caster Plates and Ground Control Race Swaybars w/ links
    • Spare aluminum radiator w/ 16 curved spal puller fan
    • AKG Engine and Transmission Mounts
    • RallyRoad Transmission brace
    • Driveshaft Shop Driveshaft (The new version with CV)
    • Porsche 996 Front and Rear Calipers w/ Full OEM rebuild kit (pistons and seals). These are the ones that will work with Rallyroad Brackets
    • Spare OBDI and OBDII Wiring Harnesses and DME’s
    • Stock E36 M3 3.15LSD
    Ellay, CA
    BMW Z3 3.0 VF SC'd
    ...do you have the dyno sheet showing the 600whp? I'd be interested in seeing the torque number and both curves.
    "You don't win silver....you lose gold."
    Joliet, IL
    Out of Service
    Dyno
    Sent from my SM-G950U1 using Tapatalk
    Joliet, IL
    Out of Service
    Joliet, IL
    Out of Service
    May 2015
    New York
    2004 M3
    Where is the car located?
    Joliet, IL
    Out of Service
    Plainfield, IL.
    Shipping the car is no problem. I have arranged many shipments. This car came to me from Georgia
    NY
    skateboard
    Fancy
    Mar 2008
    kernersville north carolina
    2003 chevy 2500 dmax, 1998 corvette coupe
    Hi, I'm interested in the car. Have a few questions if you don't mind. Bradleyclarkdrafting at gmail dot com shoot me an email.
    Joliet, IL
    Out of Service
    Quote Originally Posted by tarheelturbo View Post
    email sent
    Joliet, IL
    Out of Service
    Joliet, IL
    Out of Service
    Jul 2012
    NJ
    E36 M3
    Bump. If i only had the money. Nice build!
    Its interesting to see how corrosive some Non BMW coolant can be on aluminum cylinder heads.
    Mar 2018
    Arlington Heights,IL
    E36 m3
    Hi,
    I live northwest of Chicago. Joined the forum to get a hold of you. I’m very interesting in purchasing your car if you still have it. let me know when I can come see it. I’ll message you my phone number.
    Thanks!
    Mar 2018
    E36 m3
    I was trying to figure out how to message you directly but it won’t let me. Please give me a call at 847 five 2 nine two four 3 four. I’m very interested in the car and local.
    Thanks,
    George
    Joliet, IL
    Out of Service
    Aug 2008
    GA
    06 MR
    i cannot believe this thing is not sold yet man.. wish i could take it off your hands
    Joliet, IL
    Out of Service
    Joliet, IL
    Out of Service
    Car has been sold
    Feb 2022
    UT
    1995 M3
    do you still have the felony form fenders for sale?
  1. 1995 BMW M3 Turbo (600whp, Built Engine, GTX3852R, 210mm Diff, Coilovers, and More)
    By cragg56 in forum Forced & Chemical Induction Parts
    Last Post: 03-23-2019, 09:06 AM
  2. Replies: 10
    Last Post: 10-24-2017, 03:17 PM
  3. Replies: 1
    Last Post: 06-19-2015, 07:18 PM
  4. FS Black 1995 BMW M3 rear seats 5 pcs fold down, Black Vaders and MORE
    By m3luckyoo in forum Exterior Lighting & Body Parts
    Last Post: 05-22-2008, 01:32 AM
  5. FS:1995 BMW M3 TURBO Built & Previously owned by Diogo Azevedo
    By 99turboazevedo in forum 3 series & Z Series
    Last Post: 08-19-2007, 01:18 PM
