Results 1 to 2 of 2
Thread: Camber / Caster Options Better your Handling
    Mar 2001
    Amesbury, Massachusetts
    BMWs and Mini's
    Camber Plates, Caster Adjusters, Camber arms, and more
    One trick for improving the handling in your BMW is to add negative camber to the front wheels. This will increase the tires’ contact patches with the ground during cornering. More rubber on the road means more grip: BMW typically sets mild camber in the front to create understeer. If you're on a stock setup, you are giving up speed and adding time because the front tires run out of grip on the track or autocross sooner than they should.
    Increasing the negative camber on your BMW will reduce understeer and prolong the life of your tires when used on the track. Our plates simply bolt on top of the factory upper strut bearings and increase negative camber to your desired setting.
    Many BMW models, like the E46 M3, have unique suspension geometry. The individuality of their orientation requires specific engineering and design to allow proper motion ratio and strut angles in order to reduce bending forces on the strut under extreme conditions seen when using the camber plates. By designing each camber plate kit for each chassis we have been able to specifically tailor the plates to each vehicle’s most effective fitment and adjustability.
    No adapters are necessary for these plates, and camber/caster adjustment is a breeze thanks to our modular design. Outfitting your BMW with the Turner Street Camber Plates will give your car the handling advantages of a properly adjusted performance vehicle.
    Camber and Caster Correction and Upgrades
    Camber Plates
    Toe Arms
    Caster Correction
    Camber Arms
    Bushings
    Turner Motorsport
    / // Parts and Performance for BMWs
    16 South Hunt Road
    Amesbury, MA 01913
    800-280-6966
    info@turnermotorsport.com
    Mar 2001
    BMWs and Mini's
    Dial in your suspension for optimized performance.
    Turner Motorsport
    16 South Hunt Road
    Amesbury, MA 01913
    800-280-6966
  1. Help- Better understand CO, Camber/ Caster ect
    By Garrett M in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 01-07-2007, 10:40 AM
  2. Ground Control Street Camber/Caster Plates
    By hccyong in forum 1991 - 1999 (E36)
    Last Post: 11-24-2002, 07:45 PM
  3. E36 KMAC Adjustable Camber/ Caster Mounts
    By sgort2 in forum BMW Parts For Sale
    Last Post: 07-17-2002, 10:43 AM
  4. E36 KMAC Adjustable Camber/ Caster Mounts
    Last Post: 07-12-2002, 06:29 PM
  5. List your handling mods!!!
    By Jared in forum 1992 - 1999 M3 (E36)
    Last Post: 02-13-2002, 11:36 PM
