Results 1 to 16 of 16
Thread: E39 Factory AUX Input Kit DIY w/NAVIGATION version
    CT
    E28, E32, E39, E53, E90
    Finally installed my BMW aux kit with the navigation version. Pretty sure the E39/E46/E53 procedure is the same since the kit part number is the same for all models.
    Link: https://youtu.be/EI0bPOL9CI8
    Lawrenceville, GA
    4 BMWs.
    Funny, I did the same thing to my e53 yesterday. It was cake. "Hardest" part was drilling the hole for the aux in in the glovebox.
    Apr 2003
    Seal Beach, Ca.
    2003 540s, 2000 740s
    2 things.
    1) Nice video. Clear & easy. I might add if you want to make it a bit easier to remove that plastic frame around the 16x9 monitor, you can hit the top, left button that opens the monitor to allow access to the cassette tape. Then, while the face is open, just slide in a cassette (but not all the way in) & that will cause the face to remain open, which gives you really good access to the plastic frame.
    2) I've had my 16x9 monitor out of my 2003 540 a couple of times. While it's been out, I've never noticed that black connector for the AUX input cable. Are you sure the e39's have that connector?
    <== Steptronic Sealbeach740
    2000 740i sport: 74k Green/Tan chrome MPars, clear corners, quad brake lights, AIC hi-beams, Hoen fogs, 16x9 screen, MKIV, TFT LCD screen in back, license plate backup camera with "on demand" switch, iPod audio/video (CDC/iPod audio switching, iPod video on 16x9 screen), Basslink, gauge rings, ///M pedals, switched steptronic +/- shifting mode, E46 paddle shifter steering wheel, Dinan engine & tranny software upgrade, DDEs controlled via Euro fog light switch, painted calipers with "BMW" lettering, windows up/sunroof close via remote.
    2003 540i sport: 81k, Sterling grey/grey, MKIV Nav, PDC & CWP - Added license plate backup camera with "on demand" switch, paddle shift steering wheel, windows up/sunroof close via remote, Akebono's, painted calipers with "BMW" lettering, quad brake lights, iPod audio via AUX mode/video via 16x9 screen, BMW TV tuner, ///M pedals & gauge rings.
    USA
    2003 530iA Sport
    The aux input started with production date 09/02.
    2003 530iA Sport - Titangrau Metallic/Schwarz Montana
    Build Codes: ZSP/ZPP/ZCW. Born on date: 09/02, Dingolfing, Deutschland
    |NAV MKIV WAZE | PP | CWP | Xenons | Style 42s | Rear Shades | OEM ULF Bluetooth | Euro Armrest | Beisan Vanos Seals | OEM Aux Input |
    Oregon/Ukraine
    E39 M-Sport F30 M-Sport
    Quote Originally Posted by jagerhund View Post
    Even for nav models?
    E39 WhatsApp Chat Gruppe
    USA
    2003 530iA Sport
    Quote Originally Posted by RuskiE39 View Post
    Yes, that is correct. I have not seen information demonstrating anyone having the factory AUX input available on a build earlier than 9/2002.
    Once you pull out the NAV check carefully on the wiring harness and you will find the AUX cable bundled/wrapped with the NAV wires. If you don't look closely can be easy to miss since plug end is very small. The system will automatically show AUX as source option once line is plugged in.
    I simply plugged in a cable, leaving the wiring inside the dash and ran the wire down and out the carpet panel by drivers side of the console. The wire is out of the way. I then plug into my iphone, and mount my iphone in dash vent magnetic clip mount, works awesome, MP3, streaming talk radio, WAZE all at my fingertips.
    Attached Files Attached Files
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Does anyone have a part number for the 09/02 Navigation harness with the auxiliary plug? Seems like the best, most factory way to retrofit the aux-in for pre-09/02 cars.
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
    Aug 2015
    Oconomowoc, Wisconsin
    01 750il, E38/9 Parts
    I'd be interested too for my 01 e38
    Sent from my Nexus 6P using Tapatalk
    --- 750il Maintenance/Restoration Thread --- E38/9 Parts Cars --- YouTube Channel ---
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Looking at nav harnesses on eBay for $445... yikes. Is the auxiliary plug available separately from the main harness?
    Nate J.
    Lawrenceville, GA
    4 BMWs.
    That's how I installed it in my 528i 10/98 production (with 2004 e53 business CD and adapter harness) Instead of drilling the hose I left the cable coiled in the glovebox and just run the aux cable out the side of it. Works perfectly. Someone had already installed AUX in on my 8/02 M5, so I'm not sure how they did it.
    Sep 2009
    Columbia, SC
    2003 BMW 540iT
    On my 04/02 built 2003 (it was marked as pre production on the build info), it was taped to the nav unit harness. Untapped, ran cable and plugged in. Success. Harness was like thirty five bucks new in bag from a bmw dealer in Nashville selling a few online
    -Nick in Columbia, SC
    BMW Chariots:
    03 BMW 540iT
    Others..
    89 Colony Park, 03 Town Car, 07 Tundra
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Huh, lucky. I doubt many other pre-09/02 production cars would.
    Nate J.
    USA
    2003 530iA Sport
    "On my 04/02 built 2003 (it was marked as pre production on the build info), it was taped to the nav unit harness. Untapped, ran cable and plugged in. Success. Harness was like thirty five bucks new in bag from a bmw dealer in Nashville selling a few online"
    Interesting, I wonder if people could order it as an option prior to it becoming a standard installation item.
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    No, his car was likely a development, demonstration, or press mule. Hence pre-production on the order.
    Nate J.
    CT
    Quote Originally Posted by computiNATEor View Post
    that's pretty cool, I haven't heard of "pre-production" models before
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by rbelton View Post
    Every car from every manufacturer requires development and fine tuning. At some point, there will be a prototype built, even if it's just to test a new PDC system or radio. It's extremely rare that those test cars make it into the mass market.
    Nate J.
  1. E53 X5 / E39 Factory Auxiliary Audio Input Kit DIY *Video Inside*
    By rbelton in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-22-2017, 05:26 PM
  2. E53 X5 Factory Aux Audio Input Kit DIY
    By rbelton in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 11-03-2015, 12:08 AM
  3. E39 Wtb e39 oem aux input cable
    By starfox5194 in forum Car Audio & Electronics
    Last Post: 07-17-2013, 10:53 PM
  4. E39 FS: OEM Aux Input Kit (E46 E39 E53 with nav)
    By ///M3Mike in forum Car Audio & Electronics
    Last Post: 02-01-2009, 08:25 PM
  5. Aux Input Install DIY!
    By Marvelphx in forum 1999 - 2006 (E46)
    Last Post: 06-26-2004, 08:11 PM
