Page 3 of 3 FirstFirst 123
Results 51 to 69 of 69
Thread: Need help e39 540i SC reach AFR
  1. #51
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Quote Originally Posted by tptrsn View Post
    Well, it certainly should help! What are you using for your piston ring end gap measurements?
    Never done bro.
    Never done.
    e39 540i 6speed Supercharged,
    E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
  2. #52
    DeWitt, Michigan
    '97 540i/6, '97 328i
    But you are installing new piston rings, right? You definitely want to make sure the end gaps are at the correct dimension so they don't but together and ruin your new engine.
  3. #53
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Deamn, perhaps that is the reasson. Never paid attention on that.
  4. #54
    DeWitt, Michigan
    It's a very important step in building an engine that will see forced induction (any engine really, but ESPECIALLY for forced induction). The additional heat of combustion causes the rings to expand extra, and when the ends butt together, the rings grab into the cylinder walls, breaking the ring lands of the piston, breaking the rings themselves, and tearing up the cylinder walls.
  5. #55
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Dov, as Thad said, don't skip this step. You are at an advantage now to get this gap set correct vs the rest of us with stock gaps hoping we dont trash our motors. This fear is why I got the meth and now the intercooler to keep the ring temps as low as possible. Good luck with the build.
  6. #56
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Yeah, will pay attention on that.
    Quote Originally Posted by philly98540 View Post
    Already asked to rebuild engine and check gaps as per instruction in Ring package.
  7. #57
    Mar 2012
    Lansdale, Pa
    Gotta go wider than standard gap for FI.
  8. #58
    DeWitt, Michigan
    Yes! "Build 'em too loose and nobody will know. Build 'em too tight, and everyone will know."
    I like to use the largest multiplier that is listed in the specs, always works great:
  9. #59
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Engine is ready and i drive it to car wash station. Afr was grate 14.7 and everything was good. After washing finished i drive my car to home and realized that it is again become below 10 afr. Sometimes it is trying to come 12 but then again below 10. Opened oil checking sub and full loaded gas to check back pressure assuming pistons cracked again. But nothhing and pistons ring holding pressure.
    I cannot understan what does this engine needs from me...?(((
  10. #60
    Mar 2012
    Lansdale, Pa
    You got that put back together and driving already? Superman! Did you set ring gaps prior to re-assembly?
    Not sure why your AFR is not correct? What are your fuel trims?
  11. #61
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Yeah, gaps done. Fuel is 90 octane russian standart. Fuel pressure holds 3.5-4 bars.
    Is that possible that my filter does not allow pass enough and injectors cannot sprink?
  12. #62
    Mar 2012
    Lansdale, Pa
    Not fuel pressure. Fuel Trims from INPA.
  13. #63
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Today will check it.
  14. #64
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Morning Gents,
    Just made INPA diagnostic and have below video. I do not know exactely but for me looks like some problems with lambda. Isn't it?
  15. #65
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    It was good leasson and learnt for me to face with such a problem. Finaly i can say that issue solved. As you may know i have an AFR gauge on my second engine bank which reads driver site of engine. Today done video above where i noted that my bank 1 lambda is working properly and second one is not afr 10. I decided to change their place and noted that afr become 14.7 but exhaust still supereach. That means now lambda from bank 1 & 2 changed and problem started on bank 1. One of lambda is died and that was a reason. Tommorow will change.
  16. #66
    Mar 2012
    Lansdale, Pa
    There you GO! Bad lambda = bad fuel control.
  17. #67
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Bro, the worst thing is i changed few weeks ago my lambda but nothing changed. I put then my old lambda back. Today when i changed their place i did not realize any thing. Only after all adaptation reset.
  18. #68
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Chnged and reset adaptations. Engine works very well...
  19. #69
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Noted some horse power lose as expected. Drived against a car which usually 3 body behind me after 1km. But now i have a bit more gap against detonation. Also noted that all my power is until 6000rpm. After just loosing power and car does not run well. Any idea?
  1. Need Help - E39 540i Noise from Rear End
    By bimmeracer3 in forum 1996 - 2003 (E39)
    Last Post: 09-10-2014, 09:14 AM
  2. need help e39 540i..
    By BEAST 5 in forum 1996 - 2003 (E39)
    Last Post: 10-27-2010, 11:09 PM
  3. Need help e39 540i wheel caster off
    By dpatel1026 in forum 1996 - 2003 (E39)
    Last Post: 12-04-2006, 09:33 PM
  4. HELP: E39 540i 1997 Shimmy at 80-90KPH
    By mz3bo in forum 1996 - 2003 (E39)
    Last Post: 12-10-2003, 10:20 AM
  5. Need help with Dinan SC kit!!!
    By Ali in forum Forced Induction
    Last Post: 11-24-2002, 08:42 PM
