Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 69
Thread: Need help e39 540i SC reach AFR
  1. #26
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Busted ring land! Sorry to hear Dove. Rebuild or new motor time.
  2. #27
    DeWitt, Michigan
    '97 540i/6, '97 328i
  3. #28
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Quote Originally Posted by philly98540 View Post
    Gents, want to make pol. Contract engine 1000$ or sleveeng my current engine which cost about 700$.?
    e39 540i 6speed Supercharged,
    E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
  4. #29
    Apr 2016
    the great pacific n.w.
    540it, 540sedan, 540-6 s
    What, no prize?
  5. #30
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Quote Originally Posted by wagons ho View Post
    What, no prize?
    It was unanimously voted to send the prize account funds to hurricane relief this year, therefore all prizes will be virtual only until further notice.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  6. #31
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Shal i buy contract engine or sleve mine?
  7. #32
    DeWitt, Michigan
    There is no question, sleeve yours if you want to make some real power. Add good rods and forged pistons, of course, then you're good to go.
  8. #33
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Ok, after checking engine did not find any damages in cylinders. Decided to mill/grind cylinder heads and built engine with special head gascets. Tu engine has gasket with 3 metal list. 2 of them 0.37mm and one in center is 1mm. Original gasket is 1.74mm. I bought 2 gasket and put them in next position.
    1. Thick 0.37mm
    2. Tall 1mm
    3. Thick 0.37mm
    4. Tall 1mm
    5. Thick 0.37mm.
    Overall Thicknes is 3mm. Expected compression is 9.
  9. #34
    DeWitt, Michigan
  10. #35
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Quote Originally Posted by tptrsn View Post
    That seems great! Are you going to use regular head bolts, or some studs?
    I think regular. Or you suggest some special one?
  11. #36
    DeWitt, Michigan
  12. #37
    Apr 2016
    Raceware has stud kit for approx $180.00 us. Probably a really good idea, and reusable on the next motor.
    And what about regapping the rings while it is apart?
  13. #38
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    My plan is decrease compression. Built engine to be able to drive car and start with instalation of front or air to water cooler as philly did. I think 90% i will proceed with Philly setup.
    What is bennefit of aftermarket studs?
    New orings Getze will be used.
  14. #39
    DeWitt, Michigan
    Where have you seen that price? That is not bad at all...
  15. #40
    Apr 2016
    My bad. Stupid website defaulted to the base kit.
    Not that i can buy anything right now anyways.
    $431.00
  16. #41
    DeWitt, Michigan
  17. #42
    Nov 2011
    Derby UK
    1999 BMW540 Supercharged
    He had us going there Thad lol.
    1999 540 Auto with Eaton M112 supercharger
    Airlift 3H/P management, M5 steering box, M5 LSD, Eibach/Dinan front and rear anti roll bars, PM Modifich door boards, 4 Eton 6.5s, Sound Magus VS3500.1, 2 x 10" Kove audio subs, Alpine ICS X7 Headunit, 19" BBS Hammer Sports RT245/RT246, Muffler delete, electric coolant fan.
  18. #43
    DeWitt, Michigan
  19. #44
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Step by step building my engine with new compression 8.9. Chain become tight but took chain holder or tightener (do not know exact name of that) from m62 non tu and chain now is ok.
    Hybrid engine )))))
  20. #45
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    I filled my combustion chamber by oil. Result is 70cc. Stroke length 82.7mm. Diametr of cylindr 92. We have now compression 8.9
  21. #46
    DeWitt, Michigan
    Was that with the head on the block and with the piston at top dead center, or just the combustion chamber volume with the head laying on a bench?
  22. #47
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Yes, it was with heads builded and piston on dead point. Hope, will avoid piston broking situation in future.
  23. #48
    DeWitt, Michigan
    Well, it certainly should help! What are you using for your piston ring end gap measurements?
  24. #49
    DeWitt, Michigan
    And I just re-did your compression ratio math for fun. I really like the result (which agrees with your result at 8.854:1). Exciting stuff!
  25. #50
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Right, but mine is 8.91 due to litel milling of surface of heads. You remember video i attached. So, i am exciting what will be final result. Hope i will success and far from knocking.
  1. Need Help - E39 540i Noise from Rear End
    By bimmeracer3 in forum 1996 - 2003 (E39)
    Last Post: 09-10-2014, 09:14 AM
  2. need help e39 540i..
    By BEAST 5 in forum 1996 - 2003 (E39)
    Last Post: 10-27-2010, 11:09 PM
  3. Need help e39 540i wheel caster off
    By dpatel1026 in forum 1996 - 2003 (E39)
    Last Post: 12-04-2006, 09:33 PM
  4. HELP: E39 540i 1997 Shimmy at 80-90KPH
    By mz3bo in forum 1996 - 2003 (E39)
    Last Post: 12-10-2003, 10:20 AM
  5. Need help with Dinan SC kit!!!
    By Ali in forum Forced Induction
    Last Post: 11-24-2002, 08:42 PM
