Dear friends,
My afr below 10 with 440cc and 330cc injectors. Air consumption shows 25kg/h with 330ohm resistors 700rpm. Engine is shaking and afr is installed on driver site shows below 10. Decided change lambda sensor. No changes. Removed cam sensor, no changes and mistakes. Removed knocking sensors, no changes. Checked spark plugs, driver site is black dust. Passenger site is clean. Cleaned all sparks and pluged again. No changes. Checked injectors on fuel rump, no leakages.
Please, need your help...
e39 540i 6speed Supercharged,
E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
Engine works super reach. The only thing is engine opening unles no body give any suggestion.
By the way put new air sensor. Still engine works with shaking. Shows 25kg/h.
Just a video
You seem to have a lot of problems. Hard to help from here.
Just to be clear, we are talking idle roughness (700rpm). This means the s/c has no effect on problem.
Bank 1 runs clean, bank two is black. I would say clogged cats but you have no cats.
And wasn't your engine just apart?
Bank 2 cam timing could be off especially the exhaust cam ,which won't throw a code.
Do a compression test
Any advise friends?
I checked injectors, works good. Continue to search what is wrong with my car.
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
Additional info. My engine works super reach and afr 10 and below. Both 330 & 440 cc injectors. I checked my MAF sensor and it shows 22kg/h. Should be 16.9kg/h with 330ohm resistor. So, i changed maf but situation is the same. Somehow my maf sensor is read more air flow and engine is starting inject more fuel. Looks like some shortcut somewhere.
I still waiting your suggestions gents.
The problem is that it's only one bank. Meaning that all the common suggestions would involve the entire engine. What could cause plugs on one side to be black and fouled and one side clean?
Something mechanical. Like cam timing.
Lean misfire can look like too rich.
We don't know that it runs properly for the first 15 seconds, only that the afr is 14 while it is on the unmodified and unaltered factory start programming.
1) Take out maf resistor.
2) what is compression?
3) what is vacuum?
One more time GENTS:
1. AFR is showing below 10. Usually it was 14.7 during normal driving with resistor due to lambda doing correction. AFR is installed on driver site of engine. Engine works with shaking. During full load engine works good.
2. MAF is showing 21 kg/h, usually shows 16kg/h.
3. Driver site of engine spark plugs becoming black of smokes. Left site is ok.
4. Sometimes knocking sensor is showing knocks error in scaner.
5. One time diagnostic scanner said that lambda sensor bank 1 changed to bank 2.
6. Changed ECU, nothing changed.
7. Checked 440cc injectors on stand, they working very well. Removed 440cc injectors and installed 330cc injectors, engine works better but still super reach AFR 10 during throttle to idle. During normal driving 12-13AFR.
8. Changed lambda but nothing changed.
9. Changed MAF, nothing changed.
10. Changed cam sensor, nothing changed.
Scaner showed:
Bank 1 is reached fuel mixture limits
Bank 2 is reached fuel mixture limits
Knocking bank 2
Any advise?
Do not know whether it is a reason or no but find crack on intake manifold and seals crashing observed.
One more video gents. Does your engine also doing like this?
https://youtu.be/w4hEIPxr67M
Blow by. No it shouldn't be coming up dipstick, bad ?ccv
And that crack on intake would not effect just one side.
Cracked ringlands?
1Compression test
2Vacuum test
3Cam timing
Quick update, currently disambled headers one part and noted that metal sealing blown.
Well there you go.
Just some vocabulary tips - you disassembled "heads" ("headers" is a slang word for tubular exhaust manifolds - who knows how it got that name...) and the metal sealing is the 'head gasket'.
You are now going to want to check everything every carefully - rings & valves to be sure nothing else has suffered.
2003 M3CicM6 TiAg
Former:
Well - might have been steam coming out of the "dipstick tube" if the head gasket was bad enough, although i don't see a path to a water jacket in your pic, and usually with water the cylinders are all shiny steam cleaned, so - unless you see somethin else not in the picture, then you were probably just getting cylinder to cylinder blow out.
2003 M3CicM6 TiAg
Former:
I think i found the problem.
Attachment 614917
2 of 4 is cracked again. Lets see what is on other site.
