Results 1 to 13 of 13
Thread: How do euro city lights work?
    New England
    E36 M, E32 740i/6, 997 S
    I just got a used pair of oem ZKWs from the Netherlands and they have city lights in the high beams. The seller was kind enough to cut the wires for the single connectors and included them with the sale so I don't have to buy a harness. My only issue is I'm not sure how the city lights are wired. When are they operational? When the headlights are off? At all times?
    Jan 2003
    USA
    BMW M3
    They should light when headlight switch is turned ON. For this you would require to connect the 12V city light power wires to (for example) the front indicator power wires.
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    I have mine wired to turn on with the ignition, but cut off when headlights turn on with a relay.
    [IMG][/IMG]
    Nov 2015
    Coastal Sage Scrub
    1997 M3 Coupé CSM
    I wired mine to the indicators, which I have also modded so they do not illuminate unless indicating. That way, I can run with just the city lights or with fogs by using the parking light mode.
    Sent from my SM-N920P using Tapatalk
    New England
    Quote Originally Posted by AJLM34A View Post
    Hmm I like the sound of this. Where did you mount the relay? Did you have to use one for each headlight? What did you use for a power source that's always on when the car is on?
    Nov 2007
    Central IL
    E36
    Quote Originally Posted by yurisuika View Post
    +1 (aka just cut the third wire from the corner lights and wire to the city lights)
    BMW CCA Illini Chapter Vice President
    1995 M3
    - My Favorite DIY's and FAQ's
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    Quote Originally Posted by cohny View Post
    In the drivers bolster/steering column area.
    1 relay for both bulbs;
    https://www.amazon.com/Directed-Elec.../dp/B000CJ05WW
    In the harness for the ignition switch, Green/white should be engine running.
    [IMG][/IMG]
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    I wired mine to the parking light. So "on" with any light.
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    “Modded”? The US turn signals are dual fillament. It’s hardly worth wording as if you did something other than taking constant off the turn signal for the city light. BMW did the rest. From what I’m told by a Euro, member that’s exactly how BMW does it too and they stay on with the low beams (this part I’m skeptical of).
    Here’s how to do Euro light conversion the OE way.
    Proper OEM Euro pigtails. Unwrapped the harness and pulled the US corner parking light wire over to power the city lights. Everything is neatly redone to look OEM. New Bosch/AL/MM lights shown.
    Mar 2011
    Bellevue, WA
    Prelude-328-M3-4Runner
    I wired mine to the Euro rear fog light switch, can turn them on anytime independent of the other lights. Nothing worse than seeing the city lights stay on with the lowbeams. Also used amber led's which I think is a much cleaner look.
    CBlock
    New England
    Quote Originally Posted by Braymond141 View Post
    Awesome, thank you for the great photos. That is one immaculate E36. The seller I bought the headlights from was nice enough to include the original connector with the lights so I can do it exactly as you've shown.
    Jul 2013
    New York
    1996 BMW 318ti
    Old thread but do u still have these pictures they’re not showing.?
    Jan 2006
    Oakhurst, CA
    Quote Originally Posted by NYbmw96ti View Post
    They are fixed.
  1. How do your vanity lights work?
    By jmejiaa in forum 1991 - 1999 (E36)
    Last Post: 04-02-2008, 10:50 AM
  2. Euro city light conversion, can it work?
    By bupton in forum 1999 - 2006 (E46)
    Last Post: 04-17-2007, 01:05 AM
  3. How do Euro M3 rotors work?
    By rwindleyme02 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-10-2004, 03:51 PM
  4. How to install City light on ellipsoids
    By Bernanke in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-23-2002, 07:55 PM
  5. Euro City Lights
    By caball in forum 1991 - 1999 (E36)
    Last Post: 07-03-2001, 08:04 AM
