Results 1 to 7 of 7
Thread: LSD affordable for my e46 m3 and ls3 motor called bmvet
    May 2014
    Philippines
    BMW e46 sedan m3/ls3
    What’s a good lsd and ratio? Also an affordable one that would work on my BMW e46 m3? My rear end is stock matched to a ls3 motor. Who can help me with what’s a good ratio or lsd spec and also a reasonable price? Thanks for any help in advance.
    Apr 2013
    Kelowna, Bc, canada
    1995 BMW M3 coupe
    This was hard to read. Learn to sentence before posting.
    fairfax,va, usa
    2 E30s and a maxima
    He's from the Philippines. English is probably not his first language. Although punctuation would be nice.
    I see 3.9 to 4.10 ratios in most LS cars with the T56 transmission. You want to match your differential to your transmission.
    I don't know what would be affordable to you. Try diffsonline.com? thayer does lsd builds I think.
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    there's really nothing "affordable". Thayer quoted me almost 4k to build a 210mm diff. OS GIKEN LSDs seem to be the standard, but they aren't cheap.
    What are you using the car for? It's much cheaper just to build a welded.
    May 2014
    Philippines
    Am going to use it for drifting. And some hill climb racing
    Arkansas
    BMW, Audi, lots of jeeps
    I still can't believe nobody has made a cheap torsen for these cars. I can buy 10 bolt, dana 30 and dana 44 Detroit TrueTracs for like $475-$525. Someone needs to walk over to the Eaton booth at SEMA and talk some sense into those guys.
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    Well if you aren't set on LSD, you can pretty easily remove the OEM LSD and convert the diff to being weldable, then weld it. Probably not the best for hill climb though. I don't remember what models you need to take parts from, but it's decently documented in my build thread. Otherwise it's like $2100 for an OS Giken, and if you want to change ratio it's like $1100 for a BMW Motorsport gearset.
  1. E46 looking for some parts/upgrades for my e46 m3 vert.
    By CBe46M3 in forum BMW Parts Wanted
    Last Post: 01-22-2014, 04:50 PM
  2. Replies: 1
    Last Post: 08-22-2007, 03:33 PM
  3. I need help deciding on an exhaust for my E46 M3!!
    By nammysu in forum New England - US
    Last Post: 11-19-2004, 10:56 AM
  4. Wood trim for my E46 M3 coupe.
    By s54gasm in forum 2001 - 2006 M3 (E46)
    Last Post: 09-10-2004, 05:26 PM
  5. WTB: Used Eisenmann or BB Triflo Exhaust for my E46 M3...
    By s4play in forum BMW Parts Wanted
    Last Post: 03-04-2003, 12:56 PM
