Results 1 to 5 of 5
Thread: Can not charge batteries using +ve terminal under hood
    Vancouver, Canada
    e34 535i e31 850i
    Hey folks,
    1992 v12, swapped in new batteries. After sitting in the garage for few days the batteries were dead.. car wouldn't start. Charged batteries from post under hood with 2amps until full.. few days later they are dead again
    I have tried 3 different chargers and they all won't charge the batteries.
    The other day I heard a noise coming from the relay box while the a charger was on for few hours.
    As I'm writing this it has dawned upon me that I may not have a charging issue so much as maybe there is something draining the batteries. Not sure where to start with this.. any guidance would be appreciated.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Start by disconnecting the negative lead on both batteries, charge (say) the left-hand one fully (a 2A charger will take around 2 days for a full charge). Disconnect the charger. Use an Ammeter (set to the 10A range) to connect between the negative battery cable and the negative post of the left-hand battery and watch the current demand (doors closed, key out of the ignition, lights off etc). Even with the trunk open you should see the current demand drop to 50mA or so after 16 minutes as long as you don't fiddle with anything.
    Anything over 50mA indicates that the car has not entered sleep mode - this test can only be done with a fully charged battery (you can ignore the right-hand battery for these tests as long as it remains disconnected).
    My BMW Repair YouTube Channel
    May 2014
    Philadelphia, PA
    e31 e28 e53 e92
    They let me out again!
    The noise from the relay box was your consumer cutoff relays coming alive during charging once your batteries have been charged to an acceptable point. The clicking relays points to your General Module having faulty caps and requires a rebuild, thats whats draining your new batteries. Are you also having an issue with your interior lights and/or your windows acting up? Timms test will confirm this as it wont enter sleep mode.
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    GenMod failure
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Vancouver, Canada
    e34 535i e31 850i
    Thanks for all the input, much appreciated
  1. Battery tender connecting points under hood
    By BMWManiac in forum 1992 - 1999 M3 (E36)
    Last Post: 04-11-2017, 04:40 PM
  2. Alternator not charging battery/battery not taking a charge
    By Cuhrode in forum 1991 - 1999 (E36)
    Last Post: 02-09-2015, 05:38 PM
  3. Replies: 3
    Last Post: 01-15-2014, 07:54 PM
  4. Replies: 10
    Last Post: 11-02-2008, 01:26 AM
  5. Charging battery: Can I do it from under the hood?
    By BAVARIAN323i in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-09-2003, 08:25 PM
