BAVToys
Results 1 to 4 of 4
Thread: High Beam Issue
    Aug 2011
    Northern Arizona
    2009 328i x-drive Coupe
    High Beam Issue
    A few weeks ago one of my high beam bulbs burnt out. I have an '09 328i x drive Coupe, E92. It has Xenon HID's with adaptive headlights.
    I did some research and was confused as different sources told me different bulbs. One of the tech's at Bav Auto and a guy on another forum told me I needed a DS-1 Xenon bulb.
    Then I noticed the other high beam (inner bulbs) had burnt out.
    Got the bulb, opened the hood and popped off the access lid for the inner bulbs, and saw they were H8 Halogen bulbs.
    So I went to the parts store, got a couple Phillips H8 bulbs, made in Germany and look just like the stock bulbs I took out. Put them in and still no high beams when I flip the stalk. Neither of them work.
    If it's not the bulbs, could it be a relay or control module ?
    Jan 2019
    California
    E92 328i
    For me it was the ballast on my e92 328i for xenon headlights. I changed the ballast and now i can hear like a click noise when i turn on the high beams and turn them off. I can physically see the inner metal flap moving when i push the stalk .
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Did you check the fuses already?
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Quote Originally Posted by sandog View Post
    What happens when you pull the stalk towards yourself with the car on?
  1. high beam issue - High Beam Relay question with pics
    By Rahul325 in forum 1991 - 1999 (E36)
    Last Post: 02-15-2020, 01:42 PM
  2. Fog and High beam issue
    By lyubelsky in forum 1992 - 1999 M3 (E36)
    Last Post: 05-05-2008, 08:02 PM
  3. fuse #10 problem + high beam issue
    By wheresthewagons in forum 1983 - 1991 (E30)
    Last Post: 01-24-2006, 12:29 PM
  4. high beam issue - High Beam Relay question with pics
    By Rahul325 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 12-17-2005, 05:35 PM
  5. High Beams issue
    By Rahul325 in forum Texas
    Last Post: 12-12-2005, 12:38 PM
