Results 1 to 6 of 6
Thread: Need correct part number for giubo (flex disc) for 2000 2.3
    Sep 2003
    Hawaii
    2000 Z3 2.3
    Took apart my car only to find that the new part was too big, the center hole diameter is much larger and the overall diameter is also much larger. I received 26-11-7-511-454, Does anyone know the correct part # for my 2000 2.3? Manual trans.
    In the pics you can see the center hole diameter mismatch and the size mismatch, as well as the bolt holes not even close to lining up. Thanks for any help on this, calling the vendor first thing Monday morning
    ZZZING 2000 Z3 2.3 Oxford Green Beige/Black Sharked, StrongStrut , Whalen Knob, LeatherZ, M upper shock mounts, Koni Sport Shocks, SSR Competition Wheels, HIR bulbs, Oxford Green Hardtop
    Ellay, CA
    BMW Z3 3.0 VF SC'd
    Quote Originally Posted by ZZZING View Post
    If the bolt holes do not match up (because the new giubo is larger), then you need this giubo: 26111227410
    One type of giubo has a 78mm bolt hole pattern, and the other uses a 96mm bolt hole pattern.
    Hope this helps.
    "You don't win silver....you lose gold."
    Jul 2004
    Houston, TX
    36 Cylinders
    They sent you the automatic transmission one.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Sep 2003
    Hawaii
    2000 Z3 2.3
    Quote Originally Posted by danomite View Post
    Hope this helps.
    you are correct about the bolt pattern--ah I see, they have multiple items on realoem diagram with the same number 1
    Thanks!!
    Sep 2003
    Hawaii
    2000 Z3 2.3
    Thanks, will straighten it out with the vendor tomorrow morning, looks like I will be needing a ride to work for a few days
    Sep 2003
    Hawaii
    2000 Z3 2.3
    got the correct part installed, all is good. Also did the beisan sytems vanos kit, car is running great with 150,000 + miles. Had to lower the exhaust to get the giubo on, unlike some of the write ups
  1. Replies: 3
    Last Post: 07-16-2005, 03:12 AM
  2. Replies: 1
    Last Post: 09-25-2004, 11:40 AM
  3. Need a flex disc for a 92 325i
    By eviltwin999 in forum BMW Parts For Sale
    Last Post: 07-24-2004, 01:36 PM
  4. I need the part number for my differential plug gasket/washer
    By dansciol in forum 1983 - 1991 (E30)
    Last Post: 01-08-2004, 11:23 AM
  5. i need a part number for this
    By djbeemer in forum 1991 - 1999 (E36)
    Last Post: 07-29-2001, 12:39 AM
