Results 1 to 14 of 14
Thread: N62 headers on to m62tu engine
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Hi Friends,
    Planning to instal headers from n62 which cost me 650$. I know it is fit on right site but people said the left site is difficult and need to do a lot of modification. Will be appreciate for advise if some one faced with instalation of n62 headers on to m62tu.
    e39 540i 6speed Supercharged,
    E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    $650, really. WHere.
    Got a pic of the header for the other side?
    I used M5 headers, the only thing I needed to do was lift the engine up about 1/4" so one of the tubes wouldn't rub on the flex coupling part on the steering shaft during hard right turn under full power.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Yes bro, 650$ here in Turkmenistan. Passenger site is ok, no problem. Tommorow will do another picture.
    So, you picked up engine and left it 1/4" above original place?
    JimLev's Avatar
    Sundance Mesa, NM
    Yes, I put a few washers on the 3 studs that are on the drives side motor mount.
    San Jose, CA
    1997 BMW 540i 6 speed
    Sounds like like a Rob Siegel fix!
    JimLev's Avatar
    Sundance Mesa, NM
    Quote Originally Posted by edjack View Post
    But I used stainless washers.
    Rob would have used old rusty washers to save 50 cents!
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Jim, look at them installed on m62b44tu engine with comaping OEM headers from m5.
    JimLev's Avatar
    Sundance Mesa, NM
    That looks good, now the real question is how well will they fit when the engine is in the car.
    Did you buy them yet?
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Not yet, it is a local seller who gave it to me to try. I will buy if i 100% sure if it is fit to my car. How shal i try it? Shal i remove my engine with gear and then instal and try to put engine back in place? As i know with no removing engine i would not be able to instal it. Is not it?
    Nov 2011
    Greedland
    99 540i6, 02 X5, Tundra
    Quote Originally Posted by dovlet View Post
    You can remove front subframe to test-install
    E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
    JimLev's Avatar
    Sundance Mesa, NM
    You don't need to remove the subframe, just unbolt the engine (tranny can stay attached), jack it up 3-4" then lower the subframe as much as possible. You'll need to unbolt the steering box too.
    Jan 2013
    orlando, fl
    2001 BMW 540i 6speed
    sorry to bring back but any update to this?
    540i 6spd DUDMD tuned-weekend brute, sounds like an M5 throaty V8 "Vtec-ish" cam noise.
    Hummer- 35inch MT's, Adventure offroad package.
    check out my video gear
    https://kit.co/Lv5multimedia/mobile-videographer-set-up
    Best Oil hands down for bmw
    https://www.amazon.com/gp/product/B0...1441c0abde2552
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Impossible to instal, passenger site is ok. Driver site has many abstractions. Main is steering actuator.
    Jan 2013
    orlando, fl
    i see damn, so there was no luck... sad panda
  1. Replies: 19
    Last Post: 10-18-2016, 12:28 AM
  2. Raceland Headers on 97 M52 engine
    By sick90 in forum 1991 - 1999 (E36)
    Last Post: 07-27-2013, 12:16 PM
  3. Exhaust Header Wrapper to reduce engine bay temp?
    By bimmerpwr in forum Forced Induction
    Last Post: 08-24-2003, 02:09 PM
  4. Check engine if SS headers on OBDII?
    By M3325 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-03-2003, 07:27 PM
  5. Roundel article on 318tii swap to M3 engine...
    By Cheuk in Seoul in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-07-2002, 08:42 PM
