Results 1 to 4 of 4
Thread: Replacing the EWS and what else ???
    Jun 2017
    Texas, USA
    '04 BMW 325 Ci blk cpe
    Hey guys,
    If I replace the EWS do I have to replace the ECU also? or can I just replace the EWS and keys/ignition....Long story short the e46 got stolen this past weekend, and I just got it back today....I had a tracker put on it as soon as I got it, a two dollar Chinese devise, cops found it right away, but took them several days to release it to me. Now I have a broken window, a jacked up ignition, damaged to the right front hood/headlight/fender/door and suspension...the rest looks good, I think. It drives and all, but I would really feel better if I replaced the key and EWS...I can re-key the trunk and the door no problem....so what else do I need to do?
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Is there something wrong with the EWS? If you have to replace the locks, BMW does offer a complete set: 51210031342/51210303363 This depends on the freq that your current key uses, and it comes with all the locks, EWS, 2 Master and 1 dealership key. You will need to get the EWS aligned with the DME of course, but you will get the new keys from BMW like now.
    Now if the ignition switch area is really messed up, then you will also need to replace the lock housing and the 2 shear bolts. I would also replace the ignition switch as well for it is a known part to fail after 15 years.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Philadelphia, PA
    2005 M3 & 2004 330i
    For what it's worth, all US cars use the 315 MHz keys.
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    the EWS module is hidden under the dash far away from the ignition, and likely is fine. All you need is a new antenna ring(the black ring that goes around the ignition to read the key) ,a new ignition cylinder(you can order it by vin from dealer to match your keys), Possibly a steering column if the damage is really bad(can be bought used).
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
  1. E36 S52 burning oil, what do I need to replace the CCV and OS?
    By Pandanoid in forum 1991 - 1999 (E36)
    Last Post: 11-09-2016, 11:26 PM
  2. Replies: 4
    Last Post: 03-28-2013, 03:42 PM
  3. Replies: 16
    Last Post: 12-15-2012, 09:44 AM
  4. What else would you replace while replacing the fan and clutch?
    By OnTheFence in forum 1996 - 2003 (E39)
    Last Post: 04-09-2012, 03:04 PM
  5. Replies: 3
    Last Post: 09-10-2007, 06:13 PM
