Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 24 of 24
Thread: Can anyone advise please?
    Oct 2017
    seoul
    rexton rx 3.2
    Hey guys,
    I am a novice when it comes to wheels. I assumed my wheels were chrome. My friend assures me they are polished alloy!
    Can anyone tell me for sure?!
    (As you can see on the inside they need some serious cleaning)
    Jun 2004
    Greenville,Texas
    528i 1998 BMW, 530i 2005 BMW
    Chrome, polished alloy is bright and shiny but not near as bright. Chrome is what you have in the picture.
    Apr 2016
    Philadelphia
    1997 m3
    That’s chrome for sure. Polished wheels are a bit dull than that. Even fully polished and cleaned up there aren’t that bright.
    Oct 2017
    seoul
    rexton rx 3.2
    Thank you guys, appreciated.
    Will an acid based wheel cleaner clean up the black on the inside?
    Or is it best just the polish the outside and leave the inside alone.
    I don’t have the money to have them done professionally!
    Apr 2016
    Philadelphia
    1997 m3
    Yes an acid based cleaner should work fine.
    Just wear nitrile gloves.
    Oct 2017
    seoul
    rexton rx 3.2
    Great! I will do that. Thanks
    Oct 2017
    seoul
    rexton rx 3.2
    Regarding the outside of the wheel the smaller black bits ) next to the polished outer) will the acid bring them up good too? They are flaking in parts. I really don’t want to have to paint them
    Jun 2004
    Greenville,Texas
    That black stuff is most likely just baked on brake dust and shuould come right off with your cleaner. The flaking on the front or street side is the chrome flaking off; left alone it will continue to flake off. I'd clean it up as best you can and then paint some clear lacquer(sp) over the flaking parts to keep moisture and dirt out. Good luck with your ride.
    Sep 2010
    mid-atlantic
    70's p-cars
    Easy way to tell chrome or alloy - put a little metal polish on a white rag and rub the wheel in an inconspicuous spot. Look at the rag. If it is clean, chrome. If it is black, alloy.
    Oct 2017
    seoul
    rexton rx 3.2
    I wanted to thank each one of you guys individually but I couldn’t see a thanks button.
    So thank you to all that helped and advised
    Oct 2017
    seoul
    rexton rx 3.2
    More advise please
    Quote Originally Posted by emoore924 View Post
    I listened to all you guys and took the wheels as chrome.
    I did the test as suggested as above and the cloth turned black, which suggests they are alloy! (I had cleaned the wheel first and then tried the test with auto sol).
    Now I am really confused as you guys here have far more knowledge than me but the test shows!
    I really want to know what metal they are as I may treat them differently when it comes to the flaking bits.
    If they are polished alloy, what will happen if I remove the flaking bits on the outside of the wheel around the shiny part?
    Any thoughts are much appreciated.
    Dec 2013
    Chicagoland area
    EXOTICS
    Alloys will not flake, but display surface corrosion-discoloration, as they are not one metal coating another, but a solid metal alloy body, usually polished, painted, powdercoated.
    Chrome wheels are usually constructed of steel bodies with a thin chrome metallic coating, that due to oxidation of the base metals,
    causes the chrome coating to bubble and flake off. Simply put, alloy wheels corrode and discolor-chrome rims rust and flake off.
    Oct 2017
    seoul
    rexton rx 3.2
    Thank you for your post. I am at a loss as to what they are. Please could you look at the photo of the outside of the wheel and give me your opinion on what metal they are. I can not afford to have them professionally done. I have acid cleaner and I am not sure wether that will make it worse.
    Dec 2013
    Chicagoland area
    EXOTICS
    It seems to have a chrome face, but alloy body, inner barrel.
    I don't feel an acid cleaner would be safe, and not cause damage.
    Are you sure those are not chrome-plastic hubcaps on a steel or aluminum alloy rim?
    Need much better HD-photo to really give better advice.
    If those are plastic wheelcovers, then they just pull off to reveal the true wheelface.
    Oct 2017
    seoul
    rexton rx 3.2
    Thanks for your reply.
    I am adamant there is no plastic.
    I will take a better picture tomorrow when It’s day time. And post here.
    Oct 2017
    seoul
    rexton rx 3.2
    Hey,
    here are better photos of the corroded/ flaky bits!
    please give me your thoughts
    thanks
    Oct 2017
    seoul
    rexton rx 3.2
    Here are the photos in better quality.
    please give me your thought. Thanks
    Oct 2017
    seoul
    rexton rx 3.2
    Here are some better photos
    Dec 2013
    Chicagoland area
    EXOTICS
    Yes, those photos clearly reveal the chrome coating, lifting up and peeling away due to corrosion.
    Use the acid on the area in the first photo only, as a test application. If no damage, then safe to use.
    Oct 2017
    seoul
    rexton rx 3.2
    Wheels
    Thanks for your help.
    Can I ask what would acid do on the flaking chrome? If its steel underneath I assume it won't make it look any better?
    Dec 2013
    Chicagoland area
    EXOTICS
    You assume correctly, the acid won't improve the look of bare metal.
    Clean them up as best you can, and use them as winter wheels,
    allowing you time to save some ca$h to purchase nice summer wheels come springtime!
    Oct 2017
    seoul
    rexton rx 3.2
    Haha! I think I will still be broke then!
    Thanks a lot for your help
    Aug 2002
    South Bend, Indiana
    BMW 525I
    The wheels themselves are aluminum ally with a chrome plating. Chrome wheels are the least durable wheels out there especially if you use them in the winter. The chrome will just peel off in sheets and there is nothing you can do to stop that. The chrome plating is peeling off from the wheels. You can either decide to strip them down and paint them or have them rechromed.
    If ordering through the web site click through one of the banners and list "Jim" as a previous contact. The Tire Rack will direct a portion of the proceeds back to the the Bimmerforums.com site.
    Tire & Wheel Forum sponsored by The Tire Rack
    Oct 2017
    seoul
    rexton rx 3.2
    Thank you
  1. Can anyone help please?
    By mynchi in forum 1988 - 1996 (E34)
    Last Post: 12-30-2009, 08:08 PM
  2. Removing roof rails - can anyone help please?
    By Alexol in forum 2004-2010 (E60,E61)
    Last Post: 12-10-2008, 05:26 PM
  3. Replies: 2
    Last Post: 12-18-2007, 11:52 AM
  4. can anyone help? PLEASE
    By OSM e30 in forum 1983 - 1991 (E30)
    Last Post: 01-02-2007, 12:43 AM
  5. Can Anyone Advise a 3 Series N00b?
    By Bimmerhead in forum 1991 - 1999 (E36)
    Last Post: 05-21-2006, 10:02 PM
