Results 1 to 3 of 3
Thread: 730 cylinder head
    australia
    1986 535i
    730 cylinder head
    Hi all - my friend has an E32 730 - I am 99.9% sure it has a blown head gasket - I am also pretty sure that the head will have rotted out coolant passages (he ran plain water for many years) - my question is will a cylinder head from a 735 fit ? - or ones from earlier (or later) models ? Cheers. Also will I need to get new head bolts ?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    use realoem with the car's VIN and find out the correct part number, then go back to realoem first page and paste the part number into search by part number and all BMW models will be shown which use the same part number.
    Head bolts I would in any case use new ones
    Nov 2017
    Riga
    1992 BMW 730i M30
    M30B35 head fits for B30
    Quote Originally Posted by thepitscars View Post
    Hi, had exactly the same problem with running plain water. My gasket was really rotten rusty around the small coolant holes, but it should not necessary have damaged the head as it is made from aluminium. The other thing is that due to lots of rust in passages cooling performance could decrease and cause any possible overheating damages. And yes B35 head fits onto B30 motor (did it myself 2 weeks ago) it works but is not recommended as bore diameter difference is 3mm. If necessary I have photos of the process.
    You should at least clean the old head bolts very thoroughly or better buy new ones.
  1. Replies: 18
    Last Post: 08-31-2002, 11:20 AM
  2. cylinder head mods
    By juanci in forum Forced Induction
    Last Post: 08-06-2002, 03:37 PM
  3. 93-95 BMW 2.5L M50 engine Cylinder Head for sell!!
    By XTCFishy in forum BMW Parts For Sale
    Last Post: 07-06-2002, 01:23 AM
  4. Blown Cylinder Head Gasket
    By neaks325i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-21-2002, 04:04 PM
  5. WTB: Used 93-95 325i or M3 Cylinder head
    By Jesse325i in forum BMW Parts Wanted
    Last Post: 03-29-2002, 12:24 AM
