Results 1 to 11 of 11
Thread: smog/NO failed worse on new catalytic converters, help 95 m3
    Jul 2005
    san francisco
    95 m3
    Question smog/NO failed worse on new catalytic converters, help 95 m3
    hi, my 95 m3 failed smog HC so I got 2 new cats [walker, carb approved] that now fail badly on NO.
    each time I drove on highway 10 mins about 5k rpm on stock 235/40/17 rear, intake, exhaust, taller 255/40/17 front tires.
    station1, old cats, ebay chip like dinan, 5 min wait but idled at 1500
    15 mph/1667 rpm HC 99>85 FAIL, CO .12<.50 ok, NO 91<695 good
    25 mph/1872 rpm 50<=50 borderline pass, .12<.47 ok, 21<717 good
    then unplugged battery, installed stock chip & new cats
    station2, new cats, stock chip, no waiting
    15 mph/1688 rpm HC 41<85 now ok, CO .0<.50 good, NO 991>695 FAIL
    25 mph/1889 rpm 12<50 good, .01<.47 good, 937>717 FAIL
    so again unplugged battery, swapped back in ebay chip like dinan,
    drove 25 highway mi
    station2, new cats, ebay chip like dinan, no wait
    15 mph/1688 rpm HC 29<85 ok, CO .0<.50 good, NO 1168>695 FAIL
    25 mph/1889 rpm 9<50 good, .01<.47 good, 937>717 FAIL
    stock chip beat ebay chip on NO [stock slightly worse on HC] but old cats did much better than new cats on NO.
    Does obd1 need some # of miles before it's good to smog?
    Help, any advice?
    thanks!
    An.
    -An
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    If it were me, I'd change the O2 sensor, and the plugs. Use the stock chip, and go do the test again. Also check to see of you have any stored codes. (do the OBD1 stomp test)
    Nov 2002
    Washington, DC
    E30 E36 E46 E90
    Most aftermarket cats (including the cheap Walkers) are utter garbage. Switch back to the stock cats and you will probably pass. Edit: Dunk them in citric acid before reinstallation. You may be surprised by how much crap comes out after a citric acid soaking.
    That said, you were running rich with the eBay chip. High NOx is frequently a sign of lean running. It's too bad that you threw a bunch of parts at this with a very marginal result. You probably could have put a few gallons of E85 in the tank and passed that way. (A bit of E85 mixed in trades HC for NOx. You had plenty of NOx headroom before you messed with it.)
    2011 M3 Sedan
    2006 GMC Sierra 2500HD LBZ
    1999 323i GTS2
    1995 M3 - S50B32/S6S420G/3.91
    1990 325is
    1989 M3 - S54B32/GS6-37BZ
    Hers: 1996 Porsche 911 Turbo
    Hers: 1989 325iX
    Jul 2005
    san francisco
    95 m3
    prior cats were walker too; anyway I reverted to stock chip, mechanic cleaned valve carbon, fixed crack in new cat installation then passed smog on 0 NO w/ 1 day before reg expires =)
    -An
    Oct 2003
    Seattle
    99 M3
    I have heard to run 20 mins before testing. New aftermarket cats might have high flow and not get HOT easy.
    California, Sunnyvale ( 4
    99 m3
    I cannot believe you are actually trying to legally smog your e36 m3.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by BMW 750 View Post
    Which city/state do you reside and what ‘opportunities’ are you offering?
    RRSperry's Avatar
    Mar 2002
    Eldersburg, Md
    why not? Mine passes the tailpipe treadmill test every two years.
    Aug 2008
    North Potomac, MD
    2011 E90 328i
    Does car run hot? Any other mods?
    Nov 2015
    Coastal Sage Scrub
    1997 M3 Coupé CSM
    I have to have my '97 SMOG'd, but the CEL has been going off again and again. I had a track pipe on it and post-cat O2 sims and after I took it to the shop to get a sheered header stud replaced in the Spring, the CEL had come on just before I picked it up and immediately came back on after he cleared it. So now in having it fixed up to pass SMOG this year I put the cats back on and I had the code cleared, but it came on after 55 miles. So then we found one pre-cat O2 sensor was not oscillating so it was replaced. Then the CEL came on after 35 miles and so the other pre-cat went out. Picked it up this afternoon and drove 85 miles today, hard up the canyon roads sticking it on redline in 2nd often, and all seems good finally, no CEL.
    Finally I can get my tags and be compliant.
    So $460 in parts and labour to have it fixed on the sensors... I guess isn't that bad to know it is running perfect now. Else I could have dropped $300 on "The SMOG Guy" to have my tags and a rough idle and excessive afterfire and have everyone think I was cammed.
    I just wonder if those sensors are gonna die again after I put my track pipe and sims back on. Maybe it was because they were too old and they couldn't take it? Who knows.
    So I guess my point is take a look at the pre-cat oxygen sensors. I know the OBDI is a bit different but should be a starting point.
    RRSperry's Avatar
    Mar 2002
    Eldersburg, Md
    The post cat sensors are only monitored to tell you if the PRE cat sensors are having a problem. There is no control function associated with post cat sensors, So yes, Pre cat is the place to start. If one is bad, change both (obd2). Since there is only one sensor for OBD1, I'd change that. Vacuum leaks, (unmetered air) will cause your car to run rich. That will kill the converters too, along with rough idle, and drivability problems.
  1. smog failed worse w/ new plugs!? 95 m3 in CA
    By everbruin in forum 1992 - 1999 M3 (E36)
    Last Post: 10-19-2015, 10:52 PM
  2. WTB: catalytic converter part 95 M3
    By M3avus95 in forum BMW Parts Wanted
    Last Post: 11-25-2007, 10:31 PM
  3. 99 323is fails smog 2nd time after new catalytic converter
    By heysatan in forum 1991 - 1999 (E36)
    Last Post: 11-08-2007, 08:36 PM
  4. WTB: Stock Catalytic Converter for 95 M3
    By Orient330CIFL in forum BMW Parts Wanted
    Last Post: 06-29-2004, 05:30 PM
  5. garbage bag melted on the catalytic converters
    By psk145 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-18-2003, 07:19 AM
