Results 1 to 6 of 6
Thread: How long for check engine light to go out?
    Oct 2008
    Irvine, CA
    1993 850ci 6spd
    How long does your check engine light stay on after start up?
    i have a 93 850ci. Just replaced the O2 sensors with Bosch units. Pulled the Lambada code before that. Now I have no code visible with the reader but it takes 1:57 seconds for the check engine light to go out after startup.
    Any input is appreciated.
    Jan 2016
    Ca
    2001 525it
    If it goes off then it's ok, no pending faults, I would not worry
    Nov 2011
    VA
    Want 850
    Mine takes a few minutes after startup to go out.
    Oct 2008
    Irvine, CA
    1993 850ci 6spd
    Thanks very much for the responses. Feel better about it passing smog now.
    Jul 2015
    Melbourne, Australia
    1994 840Ci - M60, 6MT
    Mine goes out after a few minutes - I believe the source of my fault is the passenger seat occupancy sensor.
    Mind you, I'm talking about the square "CHECK" light on the bottom right of my dash, not the CEL.
    Indianapolis, IN
    93 850Ci, 09 Caddy SRX
    Quote Originally Posted by gixxerss View Post
    Good luck...glad that's behind me!
    1993 850Ci.....18 years & 165,000 miles and counting!
  1. How long between Check Engine Lights?
    By bstar in forum 1995 - 2001 (E38)
    Last Post: 12-29-2009, 08:15 PM
  2. How long does it take for brake sensor light to go out after sensor replaced?
    By jeffrimerman in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 07-22-2008, 11:12 AM
  3. How many sec for oil light to go out @ startup
    By MVEED3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-18-2006, 06:12 PM
  4. How to change the bulb for check engine light
    By mtropolis in forum 1991 - 1999 (E36)
    Last Post: 06-09-2005, 03:47 AM
  5. How do you find fault codes For Check Engine Light?
    By supercharged1.8 in forum 1991 - 1999 (E36)
    Last Post: 11-22-2002, 11:35 AM
