E39 530i Steering Play, Tramlining, and Clunking Sound
So, my 2003 530i has developed vague steering and is all over the road, especially on bumps. I've noticed a clunking sound when steering in reverse and when the car is off, the clunking sound can be heard clearly when the steering wheel is wiggled. Initially, because I had a rubbing sound from the front passenger wheel when the car was cold, I assumed I had a bad wheel bearing. However, I lifted the car up and did the wheel-wiggle test. I found play in both front wheels when wiggling at 9 and 3, but no play when wiggling at 12 and 6 (there was play along the steering axis). As far as I know, this eliminates control arms and wheel bearings as possible culprits (?). If my wheel bearings were bad, wouldn't the wheels wiggle in all directions? Also the fact that both wheels wiggle about the same amount suggests, to me, that it is a problem with the steering system. My next suspect was tie rods, which I will probably replace in the near future anyways. I had a friend wiggle the wheel while I looked around for the clunk sound and it seemed to be coming from the middle of the car, not at the wheels. So, I am suspecting either a worn out lower joint assembly of the steering column or possible a worn out steering rack. The car does leak ATF and I have to top it off every once in a while, but I always assumed it was leaking from the reservoir. ATM, the level is fine. Can anybody shed any light on this problem? It is getting pretty frustrating because you really have to be ready to respond to the unpredictable handling on bumpy roads and there is a lot of play in the steering. Thanks!
Check out my car blog here: exhaustfumes.blog
Gone: 1995 525i5, 1995 740iA, 2006 S60R 6MT, 2000 540iT, 1999 ML320, 2007 335i6
