Results 1 to 4 of 4
Thread: 2007 Z4 ABS Module
    Nov 2010
    Allentown, PA
    2007 Z4
    2007 Z4 ABS Module
    I do not know whether to laugh uncontrollably, cry hysterically or just roll the old girl over the cliff. All the ABS and Brake warning lights are on. Took it to shop thinking one of the wheel sensors had gone bad as happened once previously.
    Not so this time, Paleface! Shop claims the central ABS module needs replaced. Parts and Labor an eye-watering, totally sickening $4500! Car has 64,000. I have clothes old enough to vote; I am not rough and tough on things. Had an old E30 that I bought new and sold with 175,000 miles on the original clutch.
    My question (finally!) is this: Anybody ever had a false positive on this? In other words, were you told that your car needed this but it really did not? I just wonder if my problem is some type of sensor with a short and not the unit itself.
    Any information would be appreciated. Many thanks.
    May 2003
    Netherlands
    '07 M Z4 Roadster
    The symptoms have also been related to the battery, so check that first.
    Having said that, in my case replacing the battery did not help and I had to pay up for a new ABS module in the end.
    Douglasville Ga
    04 Z4 3.0i 6MT
    +1 on check the battery first. If the module is actually bad a used part with matching numbers should work for a fraction of the cost of new. If your local shop has BMW software they will probably be able to do an install procedure to link it with the engine module the same as putting in a new one.
  1. FS: 2006-2008 Z4 ABS Control Module (never driven)
    By Lovebandit64 in forum Engines, Performance Parts & Software
    Last Post: 09-05-2015, 05:17 PM
  2. Z4 E85,E86 FS: 2007 Z4 M Coupe 17,xxx miles
    By datax in forum 3 series & Z Series
    Last Post: 10-15-2010, 11:14 AM
  3. Z4 E85,E86 FS: 2007 Z4 Mcoupe, WA
    By herz3mc in forum Z3,Z4,Z8 Classifieds
    Last Post: 08-23-2010, 10:54 PM
  4. Z4 E85,E86 2007 Z4 3.0si Coupe, 6spd man, $25K, LA, CA
    By jcharm in forum 3 series & Z Series
    Last Post: 05-20-2010, 08:05 PM
  5. Z4 E85,E86 FS: 2007 Z4 M Coupe - new condition - low miles
    By EricMCoupe in forum Z3,Z4,Z8 Classifieds
    Last Post: 03-07-2009, 08:29 PM
