Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 4 of 4
Thread: e36 m3 fitment question
    Oct 2017
    Orangeburg, SC
    1999 BMW M3 Convertible
    Would a 17x9.5 +20 fit on my '99 e36 m3 convertible with stock height and non pulled or rolled fenders?
    Aug 2013
    1999 BMW M3 Coupe
    No way in the rear. Maybe in the front, depending on tires.
    I run 17x9 ET42 with 245/40 tires (that run wide) and if I went any wider in the rear I'd need to roll the fender. The front could probably take a 255, and I use a 12mm spacer in front.
    For the E36 M3 if you want a matching set of wheels and you want to go wide on the wheels/tires, you need the offset as high as possible and at least as high as stock which is ET41. Every mm below that is one mm less space between the tire and the fender, and these cars have very little extra clearance in the rear beyond stock. They do have a fair bit of clearance in front, and I've seen some people running lower offset concave wheels in front and higher offset wheels in back. Given that I use a 12mm spacer on mine and still have some room, you could get a way with a lower offset than stock in front but ET20 with a 9.5 inch wheel would be pushing the limit.
    Nov 2013
    Stone Ridge, VA
    1995 BMW M3 Coupe
    Keep in mind 17x9.5 +20 on stock height will look like this.
    Aug 2002
    South Bend, Indiana
    BMW 525I
    I don't think it is worth trying to make them fit. You would need more negative camber and fender work. Then you are going to end up with tires that are going to be tall on the car to fit the wheels.
    If ordering through the web site click through one of the banners and list "Jim" as a previous contact. The Tire Rack will direct a portion of the proceeds back to the the Bimmerforums.com site.
    Tire & Wheel Forum sponsored by The Tire Rack
  1. E36 m3 fitment question
    By aga080 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 02-21-2014, 03:30 PM
  2. E36 M3 Fitment Question (Offset too low -- ET Mid 20s?)
    By 95RogueM3 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 06-27-2013, 11:21 PM
  3. E36 M3 fitment question
    By HtheDuck in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-24-2011, 08:34 PM
  4. Few e36 M3 fitment questions
    By Gsharp in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 09-24-2009, 05:43 PM
  5. Another E36 M3 fitment question
    By sethla in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 12-18-2005, 04:30 AM
