Results 1 to 4 of 4
Thread: 1994 BMW 316i
    Jun 2013
    1994 BMW 316i
    Hi,I have a 1994 BMW 316i. It has 181,000 miles(289,600km) on it. Head gasket never changed, same clutch and gearbox from new. The only replacing were usual things,wheel bearings, joints and water pump. The engine doesn't burn a drop of oil. I was told the e36 316i was meant to have a weak engine or soft engine as he put it. How much longer does my engine have I wonder? Has anyone got a similar model with more milage out there?
    Jun 2010
    NY
    1997 328i
    They probably were referring to it's power output, not that the car would not last. So drive it and have fun!
    Nov 2016
    Central Indiana
    1998 BMW 328is
    I'd say the engine would be doing pretty well if it's had regular oil changes and hasn't been treated poorly (ex. constant rev limiter). The clutch is something though that may need to replaced if it's not doing well.
    Jun 2013
    Yes I changed oil every 6k miles since I bought new 23 years ago,the clutch is is still working well,no slipping no whirring of release bearing. It will eventually go someday inevitably but it sure is a lot of miles on one clutch :-)
    I think he meant it they couldn't take much hardship,I do maintain engine well but over the years I have driven it hard and revved out many times,if the engine did pack in at this stage,the car owes me nothing :-)
    Edit / Delete Edit Post Quick reply to this message Reply Reply With Quote Reply With Quote
  1. 1994 BMW 316i - IMMOBILISER PROBLEM!?
    By Bushga in forum 1991 - 1999 (E36)
    Last Post: 03-27-2011, 07:14 PM
  2. bmw 316i compact E36 1994
    By erasure32 in forum Diagnostic Software
    Last Post: 09-14-2009, 12:54 PM
  3. 1994 BMW 316i IMMOBILISED!?
    Last Post: 06-17-2009, 05:46 PM
  4. FS: 1994 BMW 325iC (Many Goodies)
    By triksterut in forum BMW Parts For Sale
    Last Post: 03-27-2002, 11:47 AM
  5. Replies: 0
    Last Post: 03-15-2002, 01:04 PM
