Results 1 to 15 of 15
Thread: Stupid squeaky squeak that I can't figure out...vid inside
    Nov 2008
    Maryland
    not enough
    Pulled the CSi from slumber, driving it this week. For a while now, I've been trying to diagnose an annoying squeak. It's a cyclical high-pitch noise, but not RPM-dependent, hopefully, it comes through in the video (I recommend earbuds to listen...it's kind of faint). It's not suspension noise, it's not clutch/gear-dependent as it makes no difference if I'm in gear or neutral, it's somewhat speed-dependent. The noise is erratic, it doesn't always happen, I've tried to replicate it by varying speeds but sometimes it comes and sometimes it doesn't (super annoying when trying to capture it on video!!). It also comes and goes at will! I could be taking off and at 30 mph, I hear the sucker. Sometimes it starts right at take off...and sometimes, it never comes u .
    Not sure if it's perhaps brake pads wearing? Maybe wheel bearing? I'll have to dig into thoroughly one day, but wanted some preliminary ideas from the group, if possible.
    Please pardon the shakiness of the video, I was trying to fumble the phone, shift, and try to capture the noise.
    CB42366 - 1991 850i 6-speed. Brilliantrot & Black Nappa Leather
    CD00144 - 1994 850CSi. Hellrot & Black Nappa Leather
    My other projects:
    Supercharged Tbirds, V8 Tbirds, V8 Mustang Convertible, Audi V8 Quattro & Audi S8
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Yep, it's actually coming from outside, i have the same thing. Sounds like the pass side, no clue on what that is!
    Toronto, Canada
    BMW 850CSi
    Center bearing
    Nov 2008
    Maryland
    not enough
    Quote Originally Posted by Dr. T View Post
    Center bearing
    Hmm....you may be on to something there Dr. T. I'll have to check that out. What kind of danger are we talking about from a worn center bearing?
    Doing a little bit of HW on the matter, changing the center bearing has "mission creep" written all over it. We're talking Guibo time, O2's, maybe some shifter work, maybe even exhaust (Eisenmanns?)...you get the picture. I'm wondering about what kind of time I have to get the center bearing fixed so I can position the project aproperly in the never-ending list of things I want to replace on the CSi.
    My other projects:
    Toronto, Canada
    BMW 850CSi
    Don’t think it’s a problem right now. Squeezing will only get worse...especially when coasting down residential street to a point where it will be embarrassing. That’s probably the time to change it. I’ve done it both by itself and while new driveshaft twice.
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    but what about automatics?
    Toronto, Canada
    BMW 850CSi
    Quote Originally Posted by dragon850 View Post
    Should be the same, no? Do the auto’s have one too?
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Autos have them too.
    There is a specific alignment procedure when these are installed, as well as a pre-loading of the center bearing support.
    Failure to do so will drastically reduce the lifespan of the new part
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    May 2013
    Salinas CA.
    1993 BMW 850CI
    Quote Originally Posted by CaifanSC View Post
    Check your back shields inside of the disc brakes. I had one on the left side that rubbed off and on while cornering, drove me nuts. Bent it back a tad, and noise disappeared.
    Nov 2013
    Whitney, TX
    97 850CI
    Quote Originally Posted by TxGR8White View Post
    Of course there is. Can you direct us to the procedure? I store all these tips as I know my day will come.
    Desecrator of all things Sacred
    Dec 2007
    Dallas, TX
    Quote Originally Posted by 72tpik5 View Post
    It is in the Factory Repair Manual.
    Nov 2013
    Whitney, TX
    97 850CI
    Should have figured. Thanks.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    This is the process (for E38, but E31 the same):
    http://www.meeknet.co.uk/e38/e38_remove_propshaft.pdf
    My BMW Repair YouTube Channel
    Nov 2013
    Whitney, TX
    97 850CI
    Thanks Timm.
    Toronto, Canada
    BMW 850CSi
    Remove exhaust and unbolt driveshaft. Mark the 2 halves of the driveshaft before unbolting and separating the splined halves or else it may not be 100% in balance again (BMW dealer did this to me). R&R Center Bearing and bolt everything back up. New or thread-lock if re-using rear driveshaft bolts or it may come loose in a few months and damage rear DS bearing - BMW dealer failed to do this on mine).
    Good time to check/replace Guibo, tranny and shifter bushings
  1. Replies: 9
    Last Post: 09-24-2014, 09:40 PM
  2. Replies: 6
    Last Post: 06-02-2010, 02:07 AM
  3. I can't figure out what's this sign mean.
    By v.b. in forum Off-Topic
    Last Post: 07-31-2003, 04:42 PM
  4. Can't figure out brake pedal adjustment
    By MPowered77 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-04-2003, 10:59 PM
  5. Can't figure out this song....
    By Preppy in forum Off-Topic
    Last Post: 06-30-2002, 06:28 PM
