Results 1 to 12 of 12
Thread: 95 vs 96+ M3 Stock Exhaust
    Jun 2008
    Surf City, NC
    1995 Dakar M3
    Question 95 vs 96+ M3 Stock Exhaust
    So I pulled my 95 M3 exhaust off the car because it was rusted out and I attempted to patch it but i think she is far gone. I have 96 M3 exhaust and wanted to see what difference it will make once I install it on my 95 M3. Will it sound the same? Will I lose or gain any horsepower?
    Oct 2003
    Seattle
    99 M3
    I believe the 1996+M3 cat-back exhaust should be a bolt-on exchange, in spite of the fact they are different p/ns.
    If anything, the 1996+M3 cat-back flows more volume, sound should be similar.
    You have them, do they appear to fit?
    Jun 2008
    Surf City, NC
    1995 Dakar M3
    I had the 96 M3 exhaust on my 95 325is, its currently out of service so I took it off to put on my 95 M3. It will bolt up fine, I was wondering if it will sound different since the pipes are larger.
    Oct 2003
    Seattle
    99 M3
    What did it sound like on your 325?
    Jun 2008
    Surf City, NC
    1995 Dakar M3
    way louder than my 95 but then again its not rusted to shit.
    Nov 2002
    Washington, DC
    E30 E36 E46 E90
    IIRC, the '96+ is double walled pipe vs. the single walled '95. I don't believe that there is a performance difference, although it should be slightly heavier.
    Edit: Net-net. It's plug and play. Run it. If you add an O2 bung to a '96+ mid pipe, you can gain power there.
    2011 M3 Sedan
    2006 GMC Sierra 2500HD LBZ
    1999 323i GTS2
    1995 M3 - S50B32/S6S420G/3.91
    1990 325is
    1989 M3 - S54B32/GS6-37BZ
    Hers: 1996 Porsche 911 Turbo
    Hers: 1989 325iX
    Oct 2003
    Seattle
    99 M3
    Actually, add a Pre-cat merge w/single bung
    Offers a blending of FWD bank and AFT bank exhaust gasses, not that signals for fuel are that refined, blended exhaust monitoring is preferred.
    Nov 2002
    Washington, DC
    E30 E36 E46 E90
    Quote Originally Posted by bluptgm3 View Post
    While I theoretically agree with you, adding an O2 bung to one side is a well proven increase. I don't know if anyone has tested for the impact of a merge in that location.
    2011 M3 Sedan
    1999 323i GTS2
    1990 325is
    Hers: 1989 325iX
    Oct 2003
    Seattle
    99 M3
    Replacing the 1995M3 cat-section Pre-cat merge with something along the lines of a Dr. Gas X-pipe with a bung is probably better than the 1996+ cat-section.
    Nov 2002
    Washington, DC
    E30 E36 E46 E90
    Quite possibly, but I can't tell someone that there are proven and consistent gains there. OBDII midsection + bung is proven power.
    2011 M3 Sedan
    1999 323i GTS2
    1990 325is
    Hers: 1989 325iX
    Oct 2005
    Tracy, CA
    e46 325XI, e36 M3
    Bumping this thread again so that not create a new one. So it appears each exhaust is backwards compatible between s50 vs s52, but is there a physical or size difference between the two axlebacks? I can’t tell from the picks but is the s50 muffler less fat than the stock s52?
    Oct 2003
    Seattle
    99 M3
    The S52 axle back flows slightly better.
    Dinan’s original E36 Perfomance Exhaust was a 1995 axle back that was opened up, partially gutted and welded shut.
    The OBDII head pipes flow slightly better than the OBDI cast iron head pipes and the OBDII catalytic converter eliminates the OBDI pre-catalyst merge. But, requires sorting out the single pre-catalytic converter sensor.
    OBDII head pipes house a pair of ‘pre-cat’ O2 sensors, the OBDII mid-pipe houses two ‘post-cat’ O2 sensors.
  1. 95 vs 96+ m3 fuel pump for AA stg II TS.
    By m3j0n in forum Forced Induction
    Last Post: 07-21-2006, 11:04 PM
  2. 95 vs 96+ M3 struts
    By mpowerdave in forum 1992 - 1999 M3 (E36)
    Last Post: 05-23-2005, 03:48 PM
  3. 95 vs 96+ M3 suspension
    By ScotcH in forum 1992 - 1999 M3 (E36)
    Last Post: 01-04-2005, 11:58 PM
  4. 95 vs 96+ M3 both stock. winner?
    By frKENm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-16-2003, 04:31 PM
  5. 95 vs. 96 M3?
    By M3lust47 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-01-2002, 08:10 PM
