Results 1 to 11 of 11
Thread: Lavender - green wire w yellow dots behind glove box e36
    washington dc
    Avus Cosmos Calypso!
    Anyone know what this singular wired plug is for? Only thing I can think of is for the parking distance control sensor, which I don't have like all US e36s...wire is about 8" long from bundle and sits closer to center of car. Thanks.
    pics:
    http://s737.photobucket.com/user/ham...?sort=3&page=1
    Apr 2016
    Philadelphia
    1997 m3
    Does your e brake light on the cluster illuminate when you apply your e brake?
    washington dc
    Yes it does. I just checked.
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    Whatcha doing back under there Edger?
    The Netherlands
    DE-spec E36 328i/M3 cab
    pics? There are so many wires located there going to anywhere, it's hard to single out one particular wire.
    IG:
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    The only single loose wire in that area is the alarm hood pin wire.
    GE=yellow
    [IMG][/IMG]
    washington dc
    link to pics posted. Thanks guys!
    The Netherlands
    That’s not factory, but normally that wire is alarm related. Hoodswitch (and) radio switch.
    IG:
    washington dc
    Folkert, it looks pretty stock to me down to the dried out fabric..tape. I've been in this area before many times on our other e36s, but I never noticed this plug before. Then again I never disconnected the whole assembly mass so our other e36s could have them too. Rich, I was installing a mass of wires through the battery terminal hole to accommodate proper gauges.
    I'm still in love with the platform after so many decades...too bad no one makes replacement door panels. I think that is what many of us need eventually.
    Feb 2001
    So Cal
    1997 M3 Sedan
    Quote Originally Posted by scooper View Post
    I read a DIY where the guy said he used epoxy to fix the door panels. (assuming it's just the cardboard structure that needs repair) I just used some on mine (some of the slots that receive the clips at the top of the door were cracked, nothing too major), it seems like a good repair, but time will tell.
    97 Estoril/Black M3/4/5
    "Although we've experienced an M3 sedan with an automatic, our test car came fitted as God intended, with a 5-speed manual ..."
    Road & Track May 1997, testing the M3 Sedan
    washington dc
    I've had success with liquid nails but similar stuff to epoxy. Thanks for replying my thread..
  1. blue wire w/orange connector behind glove
    By evol777 in forum 1991 - 1999 (E36)
    Last Post: 04-17-2009, 07:15 PM
  2. Wiring Behind Glove Box
    By busterhax in forum 1992 - 1999 M3 (E36)
    Last Post: 03-04-2009, 03:22 PM
  3. Fuses behind glove-box?
    By kwl in forum 1991 - 1999 (E36)
    Last Post: 10-08-2005, 05:01 AM
  4. What is the blue box behind glove box?
    By johnny010 in forum 1991 - 1999 (E36)
    Last Post: 03-15-2003, 01:32 AM
  5. panel under and behind glove box?
    By dr z in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-06-2002, 03:55 AM
