Results 1 to 5 of 5
Thread: Strange Rough idle issue
    Mar 2013
    Savannah, GA
    2008 BMW 328i Sedan
    In have a 2008 BMW 328i N52 engine with about 118k on the motor. I replaced the plugs at 100k and thermostat at 105k. I知 having an issue with my Crankshaft position sensor (failing slowly) after an attempted replacment (the new sensor wouldn稚 register) i put the old one back in so i get the standard SES light. Also my fwd upper o2 sensor is failing. Just wanted to give a back story
    currently every now and again i start the car and it runs like crap when its idling, but the second i turn it off even if it is not warm it is completely fine no issues with the idle. It has me baffled so I知 curious to know if you thinks its just crankshaft sensor issue or maybe something else going on. I under stand there are 2 major issues the fwd upper 02 sensor and the crank sensor but I知 just curious if this has happened to any other person
    Jan 2016
    Ca
    2001 525it
    We did a crank sensor and we updated the eye level(the newest software) using ista, this may help
    Mar 2013
    Savannah, GA
    2008 BMW 328i Sedan
    I miss not sure what ista is, I have ncsexpert, and all the other standard factory and dealer software. Is this something you that is hard to do?
    Dec 2012
    North Carolina
    2009 335i M-Sport Coupe
    You need ISTA-P and an ICOM if you want to update the integration level (i-level). Definitely replace that crank sensor.
    Jan 2006
    Seattle, WA & Bulgaria
    1992 750iL highline
    If you have INPA or ISTA, check for fault codes first - they may give you additional info.
  1. Rough Idle Issue...Resolved...
    By Buildscharacter in forum 1996 - 2003 (E39)
    Last Post: 02-05-2008, 09:59 PM
  2. 540i6 Rough idle issues
    By Addissimo in forum 1988 - 1996 (E34)
    Last Post: 02-03-2006, 08:09 AM
  3. Replies: 15
    Last Post: 01-05-2005, 07:18 PM
  4. Help, Spark plug and rough idle issue
    By nicom3 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-03-2005, 09:26 AM
  5. Rough idle issue
    By jayhudson in forum 1992 - 1999 M3 (E36)
    Last Post: 05-15-2001, 11:04 PM
