Results 1 to 14 of 14
Thread: Boosting the e36 328i stock internals
    Oct 2017
    Colorado
    328i e36
    Hey everyone, I'm looking to buy a 1996 328i as a project. I plan to turbocharge it. What can the stock 328i internals handle? Do I need an ecu upgrade right away? I don't want to blow it up to fast :P
    Aug 2014
    Ontario
    1999 325i, 1996 RSTi Cou
    Just gotta send it
    Oct 2017
    Colorado
    328i e36
    Say what?
    Mar 2012
    Renton, Wa
    98 m3
    Yes you need an ecu immediately. I run 22rpd.
    Stock stuff is pretty good into the low 4s above this youll need to go with a headgasket and studs. Cutring headgasket and arps work great.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Oct 2017
    Colorado
    328i e36
    Whay do you mean by low 4s? And good to know, thank you.
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by WILDCARD55 View Post
    400hp you can generally run like 8-10psi on a factory motor relatively safely.
    1989 535i - sold
    Oct 2017
    Colorado
    328i e36
    Okay, I'm taking a look at 22rpd. When I select pre-flashed ECU, do they send me a new ECU unit with the tune?
    Mar 2013
    Upstate NY
    M3
    F**king vtwin still gonna sennnnd it.
    How much does 22rpd charge and what can *they* tune on (hardware wise)?
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Talk to Buttters. He will give you experienced advice from someone who has built cars for himself and others for 20 years. Others have not had a drivers license that long. Don't trust me. For a reference besides mine ask Meylo -- he is running 10s while driving 10k plus miles not just making claims. Butters may recommend a NickG tune. Definitely the best. Have run one since 2010.
    Sep 2009
    Syracuse, NY
    95 M3 Turbo, 08 535xiT
    I think butters has a hand in about half if not more of the cars that have been recently built.
    My advice is to go through build threads, pay attention to trouble posts, research all tuners. Once you think you decide on a tuner google the tuners name and bimmerforums to read more about people’s experiences.
    research more
    butters knowledge is def extremely valuable
    What is your wrenching ability? Can you weld or know someone that can? is car stock now? This is not so much just slapping a turbo on and going. Lots of parts getting put on the car to make a whole.
    Mar 2012
    Renton, Wa
    98 m3
    Yes
    1989 535i - sold
    Oct 2017
    Sequim,wa
    95 bmw e36
    It all starts with a turbo, than your hooked with no escape for over seeing the true cost of the build! I’ve alway ran a boxer motor and even with mega buck into to the build nothing lasts for ever when you take it to the extreme!
    We are currently building a drift car (new for us) running stock motor with head bolts and thick gasket.
    your going to need a few items =MAF ,injectors and a tune! I used miller performance.
    Oct 2017
    Colorado
    328i e36
    I currently have a turbo car but I want a BMW turbo project. The BMW is stock at the moment. I'm decent in terms of mechanical knowlage. I did my own miss and turbo replacement on my current car as well as my own maintenance.
    Virginia
    97' m52 turbo
    Quote Originally Posted by E36warbird View Post
    Boxster = junk in my opinion. Just a standard hard-ass car too work on (for the regular guy) with 'that' Porsche logo. I almost bought one and was very unimpressed with the way it handled and drove. Now... The better Porsche models that's another story... A $3,000 E36 with a modest turbo setup would hurt a Boxster.
    Building a E36 turbo is no surprise in cost. I can tell the OP that with purchasing the tools to do the job if he doesn't have them already, assuming he intends to turn the wrench, he'll spent over $6,000, easily - if he were to use quality parts.
    With that said, 22rpd is good. I haven't tried any others. But Zack at 22rpd is a cool guy and would be willing to help you mechanically as much he possibly could if you were too encounter issues.
    Butters is great for anything mechanical, there's probably not a single person here who is as willing to help as much as him or knows as much as he does, hes been through it all. He should charge people for his services but hes a really good guy none the less.
    I'm pushing 7-10 psi on stock block with cutring gasket/spacer/and arps studs and 22rpd Tune. The car is quick with 10 psi and I feel that its a happy medium for the daily driver and too not break anything. (And to pull on anything else I see in the county I live in)
    If you are serious about going boosted the first step would be to check your compression to see if your engine can handle it. Check compression and post numbers here and we'll let you know
  1. E36 WTB E36 328i stock springs
    By dragonbar in forum BMW Parts Wanted
    Last Post: 01-08-2012, 05:49 PM
  2. FREE to Good Home: 1998 E36 328is Stock Exhaust
    By achilles99 in forum BMW Parts For Sale
    Last Post: 03-21-2004, 07:13 PM
  3. FS: E36 328i stock airbox (also fits M3)
    By G. P. Burdell in forum BMW Parts For Sale
    Last Post: 05-12-2003, 06:55 AM
  4. E36 328i Stock Exhaust for Sale
    By BlackTintz in forum BMW Parts For Sale
    Last Post: 04-24-2003, 11:58 PM
  5. E36 328is stock springs
    By GENE328is in forum BMW Parts For Sale
    Last Post: 03-25-2003, 02:36 AM
