For sale is a very unique set-up for the E46 M3 or F30 Non-M3 models. I have pieced together the
2 x BMW/BREMBO F30 335i/ix Brembo 4-piston aluminum front calipers which accommodate the 340x30mm rotor
BMW PNs: 34116865537 & 34116865538
**CAN HAVE PAINTED BLUE TO MATCH REARS IF DESIRED.
***PADS WILL NEED TO BE REPLACED, BUT INCLUDED
2 x BMW/BREMBO M Performance Rear 2-piston calipers, painted blue with an ///M logo
BMW PNs: 34218046262 & 34218046261
2 x BMW M Performance Rear Brake Pads w/ 98% life remaining
BMW PN 34216876422
2 x Authentic BMW 350x24mm 2008+ E90/E92/E93 M3/ M3 Rear Drilled and slotted Discs with 23.7mm remaining practically new
BMW PNs: Rear Left #34212283803 & Rear right #34212283804
So, essentially this is a retrofit for either the E46 M3 or direct bolt on for the F30 (non-m3) models.
According to member OCD and MY experience : Regarding mounting this rear set-up to the E46 M3: The calipers bolt to the rear trailing arm directly. However you need to offset the parking brake components and cable support outboard to retain the parking brake functionality.
**If you want to retain the rear parking brakes you need to mount the 185 mm diameter parking brake shoes, from E46 330, instead of the 180 mm diameter M3 shoes**
Feel free to make an offer. Can include front used 340x30mm rotors as well.
The front calipers have been sold. Rears available with or without rotors. $600 without or $800 with shipped in CONUS
or best offer.
