Results 1 to 3 of 3
Thread: center bearing mouts ripped
    Dec 2016
    Illinois
    2002 330i e46
    One of my center bearing mounts for my manual 5speed 330i ripped out of the body. I was wondering if anyone else has had this problem? replaced the clutch, flex plate, and the center bearing less then 1000 miles ago. should i go single piece drive shaft, or fix the body? any help is appreciated thanks in advance!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Fix the body. Find a reputable body shop that’s seen the problem before. The alignment of the fix is critical.
    Jan 2016
    Ca
    2001 525it
    You should check the driveshaft u joints and make sure they are moving, flexing freely
  1. Issue after changing guibo and center bearing help
    By Blazin95Red325i in forum 1991 - 1999 (E36)
    Last Post: 03-16-2005, 11:31 AM
  2. what is the center bearing called?
    Last Post: 02-05-2005, 01:53 PM
  3. 325 driveshaft, balanced, new center bearing
    By EMMM TREE in forum BMW Parts For Sale
    Last Post: 01-18-2005, 01:24 AM
  4. 325 driveshaft, new center bearing and balanced
    By EMMM TREE in forum 1991 - 1999 (E36)
    Last Post: 01-10-2005, 08:56 PM
  5. replacing flex-disk, center bearing, shift linkage
    By Osiicks in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-26-2003, 12:26 AM
