Hello all, newbie here. I am picking up a 1980 e21 this evening with a known starter issue. It's "heat soaked" and does not work after its been running for a bit. I am looking to replace it and have read through possible options on this forum. As I am new to the world of BMW, I am making sure I pick up the right part for replacement.
Will all e30 starters work or only those from an e30 M3? Is there a part number anyone would recommend to make sure I pick the right starter?
All help is appreciated!
Is this the one?
http://www.rockauto.com/en/moreinfo.php?pk=273751&jsn=3
Any other starters that would work? Anything I would need to modify to make this one work?
Thanks again for the input!
I'm 95% sure that is what you need.
That's the one. SR440X fits same flywheel teeth on the ring gear M10/S14. Lighter, smaller, more torque output from the E30M3.
Yours most likely needs the love tap on the solenoid. When heat soaked they all eventually stick after wear. A "tap" with a hard device allows them to keep working. Used to carry a tap stick in the car for that on long trips. Hence I find it funny when they had a sticker on my new SR440X solenoid "don't strike with hammer" .
When the bore and cylinder wears the little piston gets canted and sticks especially with heat. Try a light whack with something metal on the solenoid and bet it works.
88 M3
91 318is
91 318i
83 320is
08 X3 3.0si
Any other starters that would work? Yes, the later M30 Starters or The M5 starter
Details from 2002 Group, except M5 missing.
https://www.bmw2002faq.com/forums/to...rter-question/
"Yes the SR441X starter from a late M30 motor like that in a E32 735i from '88 through '92 and an E34 535i from '89 through '92 WILL work perfectly fine in on a M10 motor. The only thing that is of any issue is that the start signal wire for terminal 50 is a spade connector in the '02 while the SR441X starter uses round eyelet connectors. I feel the best solution is to find a spade connector adapter like that from a coil that has a 6mm post. That's what I use when converting to use one of these starters. I do not like molesting the original '02 wire harness to cut off the spade and crimp on an eyelet....
I actually prefer the SR441X starter to that from the E30 M3 S14 the SR440X.
SR441X has 1.7 KW
SR440X has 1.4 KW"
I have a new SR441X as backup,, Note the SR441X has a round terminal,,so one would need a M6(1/4") ring terminal to 1/4 inch(6.35mm) male spade terminal adapter,, which is hard to find or does not exist--An M6 ring terminal bare with a bare M6 male spade terminal crimped in tight and then heat shrinked over the crimp will get the job done, neatly.
$100 on ebay w 1 yr warranty,new, from someone with a lot of positive feedbacks, 19,000 +, 100% Positives.
Lance mentioned this some time ago here on this forum, this starter upgrade SR441X and others, this got me looking and bingo.
Randy
So, is the SR441X the starter in the M5?
a word of caution.... do not use a E30M3 for a pre-facelifted car (ignition points), they are not compatible.
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
14 f800gsa - red headed stepchild!
I have a starter i just removed if needed
