Results 1 to 6 of 6
Thread: Misfire Cylinder 1
    Jun 2010
    Colchester Vt
    2009 328XI Wagon
    Misfire Cylinder 1
    I keep getting a CEL for misfire cylinder 1. I have changed the coil pack and still comes back,even swapped with another coil to see if it was defective...Could a bad 02 sensor cause this? Usually does it when you first start the car when its cold.
    Dec 2013
    Chicagoland area
    EXOTICS
    First, what is the actual code, and from what type of scantool?
    I would inspect sparkplugs and replace if worn or fouled.
    If nothing changes, try swapping injectors.
    Nov 2014
    Quote Originally Posted by jamiec32 View Post
    Are you getting other codes? The 2005 330ci we have had similar issues, but was throwing some O2 sensor codes as well. O2 was not the issue and thus let us know if you had other codes.
    Nov 2014
    Toronto, Ontario, Canada
    2001 BMW 330Ci
    Since you only swap coil pack, then I will suggest to swap spark plug as well
    California
    325e 535i M5 325iT 330i
    Much as I hate to say it, do a compression check. On both our E46s, intermittent misfires led me to run compression checks and I found that both of them had low compression in several cylinders. Both had badly pitted exhaust valves and worn exhaust valve guides.
    Jan 2016
    Ca
    2001 525it
    Swap spark plug
  1. misfire- cylinders 3 & 4 on 530i
    By vv23 in forum 1996 - 2003 (E39)
    Last Post: 11-24-2006, 05:20 PM
  2. Got CEL, code reads misfire cylinder 2. How to fix?
    By bm3power in forum 1996 - 2003 (E39)
    Last Post: 08-19-2006, 09:03 PM
  3. Misfire cylinder #6 : WTF?
    By Hugo in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-12-2005, 01:30 PM
  4. V12 Misfired cylinder 6 could not pass smog check
    By amazonarcher in forum 1995 - 2001 (E38)
    Last Post: 05-01-2005, 08:46 PM
  5. misfire cylinders 1 through 4...help
    By gsxy in forum 1992 - 1999 M3 (E36)
    Last Post: 06-16-2004, 10:03 PM
