Results 1 to 18 of 18
Thread: Thumping noise over bumps in the trunk.
    Aug 2013
    Finland
    1999 540i M-sport
    Hi guys,
    I bought an 530d M-sport estate a few month ago.
    Only problem I have is very loud, thumping noise when driving over a bump.
    I alredy removed almost everything I could and drove, still present.
    So far cant even imagine what can be the cause.
    First I thought it is the stupid opening glass in trunk, as it was moving and wasnt firm. Adjusted that to be very firm.
    2. Removed trunk plastic etc still present.
    I will raise the car tommorow, and see if something is hitting it from the bottom. But nothing was loose when I checked it last time.
    My catless downpipe should come anyday, maybe it is exhaust that is the cause.
    Отправлено с моего SM-G935F через Tapatalk
    -E34 M60B40 + Tremec TKO 600 (sold)
    and sadly no old BMW anymore, only high powered Seat Leon Cupra 4Drive as a daily driver.
    May 2010
    USA
    08 535xit
    i would look at your subframe bushes to see if they are perished. there are 4 of them.
    G~
    E61 Mods: Trailer Hitch/wiring, Cargo cover roller fix, Backup camera, H&R springs, ER charge Pipe, Mishimoto catch can, boost gauge, intake scoop, JB+, CSR Rear Spoiler, Full SAT retrofit.
    Coded: legal disclaimer removal in iDrive, auto folding mirrors on lock, turn signals in HUD, fan speed indicator on when in auto, Doors unlock when key removed
    E39 Mods: Euro dash conversion, Dinan exhaust, Dinan suspension with Camber kit, 2.81 differential, flappy paddle with double pull M mode activation/deactivation, backup camera, Video playback on Nav computer (iPod Video for video storage and playback), stereo video playback through DSP, MKIV computer, RPA Tire Pressure retrofit, Intravee II iPod integration, Euro armrest, HUD, Parrot BT, voice recognition module, trailer hitch/wiring, rear mounted 10" subwoofer with amplifier, lighted interior door handles, Evans coolant.
    Aug 2013
    Finland
    1999 540i M-sport
    Quote Originally Posted by Reefin Dude View Post
    G~
    I will check them tommorow after work.
    Dec 2008
    Long Island
    528iT
    +1 on the subframe bushings.
    Dec 2015
    Gardner MA
    2003 525iT, 2008 328xiT
    +1 on the subframe bushings. But if you have a subwoofer in the back passenger side and it is loose it will make a clunking sound, also make sure the battery brackets are tight and the welds have not broken.
    2003 525iT Automatic, Topas Blue Exterior, Gray Leather Interior, Sports Suspension, Sports Seats, M 3 spoke Steering Wheel.
    2008 328xi E91 (wagon) Automatic, Barberatot Metallic Exterior, Terracotta Leather Interior.
    Aug 2013
    Finland
    1999 540i M-sport
    It doesnt sound like the subframe I think.
    More like the trunk is not tight and is banging, but who knows. I will check the bushings.
    May 2010
    USA
    08 535xit
    do you have slide out trunk floor? these can clunk if there is not weight on them.
    G~
    Jan 2013
    Nashville TN USA
    '00 540iT 03 525iT
    Ours was a combination of worn subframe bushings and a mis adjusted rear hatch latch. ours needed tightening., If the subframe bushings have over a 100k miles on them and haven't been changed, they probably need them..
    Apr 2017
    Montreal
    2003 bmw 540iaT
    Check to see if this guy is not loose. That is what was causing noise in my trunk.
    Aug 2013
    Finland
    1999 540i M-sport
    Dont have the slide out trunk, its the lifting one.
    It does have 306tkm on it, so bushings are probably dead. But one of our mechanic who also have E39 which is also M-sport but his one is individual without exterior M-sport bumpers, said his car drives much worse, and he does have bushings gone, but still no clunks :/
    I think it might be the trunk, but I adjusted it a few times so far. Have to take a look maybe cd changer or something is loose.
    Btw guys, is there poly bushings on sale? Or just the rubber ones?
    Dec 2015
    Gardner MA
    Quote Originally Posted by 2003540iat View Post
    Thats the subwoofer. Mine makes clunking sounds if I do not tighten it down "completely".
    Powerflex makes urethane subframe bushings for the e39 touring. https://powerflexusa.com/E395Series97-03.aspx
    Jun 2017
    Santa Barbara, CA
    2000 BMW 528i Touring
    Quote Originally Posted by vipeboy2000 View Post
    Is it pretty simple to tighten this? I am pretty sure my subframe bushings are shot at 222k miles and I am replacing those soon. But I think I should check other stuff, since it sounds and looks like that is what's making noise, but it could just be that's whats vibrating due to the bad bushings...
    2000 528i Touring Sport-Premium (Daily Driver)
    2015 X3 (Wife's car)
    2016 Chevrolet SS, 6spd manual (Weekend fun)
    Dec 2009
    Annapolis, MD, USA
    2012 JSW 2.5
    My bump was the battery tray. The front left weld gave out. Had a shop weld it back together:
    [IMG][/IMG]
    Aug 2013
    Finland
    1999 540i M-sport
    Quote Originally Posted by JaxPlanet View Post
    Will check that! Thanks
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Its the subframe bushings.
    Sedans don't have the issue.
    Its hard to ID always from underneath but trust us... its a TOURING PROBLEM. If the bushings have small cracks in the bottom then they have leaked out all their oil inside and now are flopping all around.
    "Meyle HD" bushings are available that are not oil filled so won't do this. That is NOT regular Meyle - if it doesnt have the gold HD seal on the box its not the right part. The powerflex only became available recently so mine are the Meyle HD and they do the job fine.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Martinsville VA
    2003-525i BMW
    My spare tire caused bumping noise. I removed the tire and then realized the sound had stopped. Grabbed some upholstery foam, like in seat cushions and placed under the tire, fixed the noise problem.
    Aug 2013
    Finland
    1999 540i M-sport
    Quote Originally Posted by Poolman View Post
    I have did that first thing.
    But so far the noise dissapeared, maybe its the trunk upholstery top cover, as there is now subwoofer, and catalytic converter pressing it down.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    You have to love this one. Now that problem was caused by:
    A. Forgot to remove battery hold down bolt before removing (forcing) the battery out of tray
    B. "Ok, Hans the bracket is in, you weld it and then let it go on to painting" Overheard on the factory floor just before the Friday shift ended....
    C. "Lets see if we can make this car jump on the next hill...."
    One of my former cars (70's US domestic) came from the factory without any body sealer around the taillight panels so you could actually see daylight from inside the trunk around the lights. New car so never hit but never finished either. You have to love old factory fit finish and quality controls. "We don't need no stinking second lookers. I do a good enough job!"
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
  1. Bump in the trunk. How much wattage does one need???
    By trendyincdotbiz in forum 1983 - 1991 (E30)
    Last Post: 04-24-2009, 01:02 PM
  2. thump in the trunk fix
    By rize in forum 1991 - 1999 (E36)
    Last Post: 05-03-2008, 06:04 PM
  3. Some bump in the trunk, 1981 320i?
    By PaidCashForMine in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-08-2008, 01:15 PM
  4. 330i, bump in the trunk progress
    By matthewo in forum 1999 - 2006 (E46)
    Last Post: 02-19-2008, 11:54 PM
  5. My sunroof rattles over bumps in the "tilt" postion!
    By Eurodriver in forum 1991 - 1999 (E36)
    Last Post: 03-10-2006, 12:43 PM
