Results 1 to 17 of 17
Thread: Koni shocks: how do I adjust the rear shocks?
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    The fronts are easy to adjust, came with that plastic tool and instructions. They are on the car and work great at 1/2 turn from soft, as recommended on this site. I didn't get any instructions with the parts on rear adjustments. I searched and watched a couple of videos, and see there are a few styles. These are PN 8040 1217SPORT, for my 98 Z3M . They have flats on the stem. I've tried turning it. I've compressed it completely and turned the top, never finding the internal tabs that some have. I guess I'm not that bright, because I can't figure it out. I emailed Koni, but no telling when they'll respond, and I want to put them in now. thanks for help.
    Thought you used the adjustment tool on the top of the strut (where it sits in the rear shock mount)?
    SW Florida
    99-01 M Cpe & Rdts, X5M
    There are three (3) possibilities:
    double-adjustable shocks (at least those from TCK) have a stem up through the shaft (like your fronts) AND a 12-position click-stop screw adjustment near the bottom.
    single adjustables *may have* the same click-stop adjustment (TCKs do) near the bottom, or...
    if there's no visible adjustment, then YOU MUST disconnect the bottom of the shock, THEN REMOVE the rubber bump-stop (buried in the upper recess around the shaft) and finally, FULLY COMPRESS the shock and turn__you should *feel* it when it engages the slot allowing an adjustment to be made.
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Randy is genius. (I know, many people already know this) Mine is the 3rd type he lists. Until he told me to take out the rubber bump stop (and that split plastic washer), I was not able to compress far enough to engage the slot. I didn't see the bump stop because it was lodged at the top of the shaft, inside the upper housing. Incidentally, mine has small holes on the top so I can poke the bump stop down to take it out. So now I've adjusted them. It was about 2 1/2 turns lock-to-lock, so I'm setting it at 1/2 turn from softest side. That is, I'm turning it all the way counter clockwise and then back 1/2 turn. Luckily, mine are not installed on the car. It seems much easier to do than it would be on the car. .......... thanks again.......... P.S. : shame on Koni, for not having instructions in the box. They have decent instructions for the front shocks.
    Batavia, IL
    00 M Coupe, 08 335xi
    Edit (Singles with an adjuster are at the top)
    Double-adjustable shocks (at least those from TCK) have a stem up through the top shaft (like your fronts) AND a 12-position click-stop screw adjustment near the bottom.
    Single adjustable (at least those from TCK) have a stem up through the top shaft (like your fronts), or...
    Oct 2003
    Seattle
    99 M3
    The (TCKline) Koni top external rebound adjustable shocks have a non-stock 12mm shaft that requires aftermarket Rear Shock Mounts.
    The internally rebound adjustable Koni rear shock shafts are stock diameter at 10mm.
    SW Florida
    Quote Originally Posted by SunzOut View Post
    True, but I really think I've seen them with only a external adjuster at the bottom too__I don't think I just imagined it__but I've been wrong before
    Maybe they were a short-lived offering, in an effort to keep the 10mm stem?
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by Randy Forbes View Post
    Aren’t the double adjustable shock adjusters at the bottom of shock body?
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    I installed the Koni shocks, have a couple of comments: ((1)) Adjusting is definitely easier off the car. Since they are so easy to take out, I will remove-to-adjust if I ever want to adjust. I don't think I will. The initial setting seems right. ((2)) One should compress the shock after adjustment, with the bump-stop on it, to seat the bump-stop at the top of the shock. Otherwise, the bump-stop falls and could get in the way, maybe even get cut by the metal shock cover, when shock compresses on the car.
    San Jose, CA
    '11 335is vert, '01 Z3M
    Quote Originally Posted by zellamay View Post
    one advantage of the shock mount reinforcing kit is that the bolts point down into the wheel well so you can remove the rear shocks without taking out the felt and doing yoga behind the roll hoops with the top up.
    Tavernier, Florida
    '99 2.8&Mcoupe, '03 Mini
    Actually, the 3rd style Randy describes are fairly easy to adjust by just removing the lower mounting bolt. Once you understand how they adjust, its pretty simple to compress and turn the body. The hardest part is poking through those top holes to get the snubber out of the way.
    -Donny
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    Welcome back., Donny.
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    I know it's old thread, but I can confirm that the instructions to adjust the rear Koni shocks do come in the box. There's a little sheet of paper, and mine was stuck to the inside of the box. I could have easily thrown it out and never known it existed. I went searching for adjustment preferences and came across this thread. Maybe it helps someone else someday.
    Nathan in Denver
    Aug 2020
    Madrid, NM, USA
    2001 M roadster
    I was installing my rear shocks this weekend, and found this video from Koni that shows the different adjustment methods https://youtu.be/ksekDSo3Dbc
    It took me a bit before I realized the bumper stop and white disc needed to be removed. I never felt any “clicks” but I could clearly feel the stops at clockwise and counterclockwise rotation. I set mine at one half turn. It was easy to do on the bench.
    Koni has another vid on the cut-a-strut process, but that’s for next weekend ;-)
    /Phil
    ‘74 tii
    dueling ‘88 E28 535is projects (aka lawn art)
    ‘93 Euro M5
    ‘01 M roadster with a sunburn
    Aug 2015
    Denver, CO
    I watched that video a couple times while my kit was in transit. Good stuff.
    Yeah no clicks for sure, but the detent is easy to feel. I just inverted the shock and compressed on a piece of thick cardboard and set mine at a half turn as well. It sounds like we're in the same boat. I'm in no rush to install and still waiting on a couple tidbits to do the fronts, as well as some fresh bushings from Rogue to rebuild the rear mounts.
    I'm thinking just a hacksaw on the front housings with a piece of tape marked at the 25mm dimension, but it's not like a slightly crooked cut won't achieve the same purpose after they're bolted in. We get to cover up our handiwork with a rubber boot regardless. I was thinking of painting the housings too, but I kinda dig seeing the factory markings so perhaps just some matte clear for me.
    I'm also still debating H&R springs vs. staying with OE.
    Sent from my SM-G975F using Tapatalk
    Nathan in Denver
    Oct 2003
    Seattle
    99 M3
    You may consider having this (replacement) washer on hand for strut build-up
    Aug 2015
    Denver, CO
    I have complete intact OEM assemblies. I have the "support" and "dust protection collar" that installs above.
    https://www.realoem.com/bmw/enUS/sho...39#31332227342
    Nathan in Denver
  1. Replies: 4
    Last Post: 12-19-2007, 10:23 PM
  2. Doing suspension, how do i replace the rear shocks?
    By GottaLoveAvus in forum 1991 - 1999 (E36)
    Last Post: 11-28-2006, 04:52 PM
  3. How do I adjust the stiffness of my rear Koni SA's?
    By rdpower in forum 1991 - 1999 (E36)
    Last Post: 12-30-2002, 12:51 AM
  4. HELP how do I get the rear tranny crossmemeber bolt off?
    By BMWM3some in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-07-2002, 01:44 PM
  5. How do i get the rear seat out of my convertible?
    By Shoe Coupe in forum 1991 - 1999 (E36)
    Last Post: 09-25-2001, 11:19 AM
