2005 E66/N62 have spent months looking for a wiring issue upsetting the comm loop, keeping the car in limp mode with xmas lights galore. Finally found a shop with TENACITY ! They found wires/harnesses melted at the VVT module in the engine bay control module box (passenger side firewall area).
Does anybody know where I can get replacements for those two plugs/harnesses that plug into the VVT module ? For reference they are x60211, a 10 pin, and x60212 a 23 pin, on the wiring diagrams, but I can't even find part numbers.
I just got a new(used) VVT module, but does anyone have some used plugs from a donor/parts car ? How about the name/number of a boneyard, I've tried all of them around the Cleveland, Ohio area.
The part number is 12-52-7-515-466 & 12-52-7-515-465 these are the plugs with out the wires if you go to realoem in section 11, engine look up picture valve timing gear, ect, shaft, actuator, the vvt module part number is listed there the little triangle to the left of the picture of the module are the connectors look at those part numbers and the wires needed are listed below it
