Results 1 to 2 of 2
Thread: VVT Module harness connectors
    Sep 2014
    Ohio
    2005 E66 745Li
    2005 E66/N62 have spent months looking for a wiring issue upsetting the comm loop, keeping the car in limp mode with xmas lights galore. Finally found a shop with TENACITY ! They found wires/harnesses melted at the VVT module in the engine bay control module box (passenger side firewall area).
    Does anybody know where I can get replacements for those two plugs/harnesses that plug into the VVT module ? For reference they are x60211, a 10 pin, and x60212 a 23 pin, on the wiring diagrams, but I can't even find part numbers.
    I just got a new(used) VVT module, but does anyone have some used plugs from a donor/parts car ? How about the name/number of a boneyard, I've tried all of them around the Cleveland, Ohio area.
    Jan 2016
    Ca
    2001 525it
    The part number is 12-52-7-515-466 & 12-52-7-515-465 these are the plugs with out the wires if you go to realoem in section 11, engine look up picture valve timing gear, ect, shaft, actuator, the vvt module part number is listed there the little triangle to the left of the picture of the module are the connectors look at those part numbers and the wires needed are listed below it
  1. WTB: IHKR Module and harness connectors
    By bonesh in forum E34 Classifieds (closing soon)
    Last Post: 11-25-2012, 12:08 PM
  2. NEEDED: wiring diagram for engine harness connector
    By funkmasta in forum 1987 - 1991 M3 (E30)
    Last Post: 02-12-2005, 12:28 PM
  3. WTB: E36 Harness Connector for factory Head Unit
    By stimpee in forum BMW Parts Wanted
    Last Post: 11-10-2004, 11:19 PM
  4. 325i speaker harness connector?
    By dragonm3 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 01-04-2004, 02:38 PM
  5. ?'s on front heated seats (harness/connector question)
    By Cobra Jet in forum 1992 - 1999 M3 (E36)
    Last Post: 08-05-2002, 01:37 AM
