Results 1 to 25 of 32
Thread: 10 Second Club! FINALLY!
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Cool 10 Second Club! FINALLY!
    Had a goal set for myself and I knew the car was capable of it. Super huge thanks and shout out to Butters! As you all know he has been my mentor and teacher through all this. Taught me everything I know! Nobody would of thought the car would be this quick. Car has had 13k miles put on since it was finished in February, daily driven. 70+ passes at the track driven to and from the track every time.
    Setup: PTE 6262 with a .63 A/R on a bone stock s52 with a cutring, copper spacer, stud combo, snow performance 50/50 water meth injection, pump 93.
    https://youtu.be/K5Ivpx0yIaY
    PTE6262 .63 A/R, Stock S52, Cutring/Copper Spacer/Arp Studs Combo, Water Methanol Injected
    10.9@131mph. #AngerMotorsports
    Apr 2006
    Minnesota eh?
    86 325es
    Awesome work, that is seriously fast for a stock s52 and 6262
    Louisville, KY
    turbo m3
    Nice!
    For 131mph trap at that weight you are at least half way into the 500whp range.
    Whose tuning?
    Jul 2005
    PEI, Canada
    2001 330i
    Congrats!
    Vancouver, B.C., Canada
    '97 M3
    What tires and size?
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Thank you. Means a lot coming from you. You know your shit! We really didn't think it'd be this quick but the more boost we kept throwing at it and the more I practiced the quicker and faster it went.
    Quote Originally Posted by BadBoostedBmwM3 View Post
    Nice!
    Whose tuning?
    It's on a 80lbs rk tunes base tune. No revisions or dyno tunes.
    Quote Originally Posted by PEI330Ci View Post
    Congrats!
    Thank you.
    Quote Originally Posted by chikinhed View Post
    26" 275 40 17 Hoosier drag radials
    Manchester, N.H.
    96 332IS 6466 turbo
    Great job, well done.
    Just don't beat my best, and we can still be friends.
    Sent from my E6782 using Tapatalk
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    Manchester, N.H.
    96 332IS 6466 turbo
    What tires ?
    Phil's left tire and my right tire.
    Seems to work well.
    1996 332IS
    Built 3.2
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    I said that last night at the track. Lol I told my girl, Chris is going to be stoked. I went 10s but didn't beat his time. Haha
    Aug 2017
    Savannah, GA
    E36 M3 Turbo, 2015 GTI,
    That's awesome...I know my car traps in the 125's on street tires..Scared to put it on stickier stuff...10's is seriously moving. Congrats man!
    Ken
    95' Dakar M3
    (GT35) 500whp+ and no clue what I'm doing....
    Steedspeed Twin-scroll Manifold, Wiseco 8.8:1 CR, K1 Rods, Supertech Valvetrain, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) Twin-Scroll 1.06 AR, Schrick Cams, TRM Tuning, 6 Speed Transmission, UUC Twin Disc Clutch, HFS-6 W/M injection, Zeitronix, Coilovers, Chassis Stuffs.
    Manchester, N.H.
    96 332IS 6466 turbo
    This car should be copied for all budget builds. Most of the veterans here would argue a few things about the build, but it obviously works. Camilo also drives this car more than the bulk of us.
    Totally easy simple build, very straight forward, very simple. Simple is nice.
    1996 332IS
    Built 3.2
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Quote Originally Posted by Quicker10u View Post
    Thanks man. Yea the car at 125 mph trap feels very good and strong. 130+ is a whole different league. You feel the front of the car get much lighter. Almost like it's floating.
    Aug 2012
    CT
    Twin turbo LS E36 M3
    I like how the washer fluid color matches the Valve cover. Thats probably the reason its moving so good.
    Nice work, seriously.
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Quote Originally Posted by dburt86 View Post
    Thanks man. How's everything with the new car going? That nova is so sick.
    Apr 2006
    Manchvegas
    Boosted M3’s
    Quote Originally Posted by E36Mylo View Post
    Congrats man.
    Keep pushing the envelope as competition makes us all faster.
    1997 Cosmos E36 M3/4/5 Boost Logic GT40/94r .85 Technique Tuning
    Stock motor
    1998 Estoril E36 M3/4/c4 Steed Speed2 Gt40/94r 1.06 Technique Tuning,
    Built motor, Best ET ( 9.63 @ 142.61 mph MS100+meth ) 10/08/21
    Best mph ( 10.08 @ 144.66mph MS100+meth ) 9/18/19
    build thread:
    http://www.bimmerforums.com/forum/showthread.php?2269817-Habbit-continued-Turbo-build-V
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Quote Originally Posted by Mod Addict View Post
    Congrats man.
    thanks a lot greg! lets plan on maybe going up next friday for one final time this season.
    Apr 2006
    Manchvegas
    Boosted M3’s
    You got it ;-)
    Stock motor
    build thread:
    Manchester, N.H.
    96 332IS 6466 turbo
    Let me buy you dinner instead of going to the track next week. Maybe it would be best for my spot on the list.
    1996 332IS
    Built 3.2
    Aug 2015
    Boston
    1999 Bmw M3
    Are we going tonight?
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Quote Originally Posted by butters stoch View Post
    let me buy you dinner instead of going to the track next week. Maybe it would be best for my spot on the list.
    Sent from my e6782 using tapatalk
    LOL
    Jan 2003
    Charlotte
    That's awesome guys!! Great Job
    1998 Turbo M3 Nick G tuned setting 5 934Whp 849Wtq @27.88 Psi. ignite E90 setting 6=
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Congrats...truly
    A reliable, daily, trackable, drag strip, queen.
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by milKt View Post
    Congrats...truly
    Agreed, piloting the car into the 10's is extremely difficult with a stick. Regardless of how much power you have. Seriously hard to do. He has done very well. I'm totally impressed. I've seen much much more powerful cars run a lot slower. My own as well.
    1996 332IS
    Built 3.2
    milKt's Avatar
    Some builds have a little extra...magic.
    Virginia
    97' m52 turbo
    Awesome sauce!
    I want mine to do 10's... I wonder if I could pull it off
  1. I finally made a 10 second video of my car
    By Sniz in forum Forced Induction
    Last Post: 06-27-2011, 10:13 PM
  2. 10 second clips of YOUR car
    By one in forum BMW Rides & Events
    Last Post: 09-08-2005, 07:59 PM
  3. Joining the club, finally!
    By Croak in forum Forced Induction
    Last Post: 10-25-2003, 12:44 AM
  4. Replies: 34
    Last Post: 04-02-2003, 07:52 PM
