Results 1 to 3 of 3
Thread: Uneven Brake Pad Wear on One Caliper
    Nov 2007
    Chambersburg, PA
    1989 325iX
    My wife's car, a 2012 e92 328xi, had a grinding sound when braking. Turns out one of the rear brake pads were worn down to nothing. What is peculiar is that the other pad on the same caliper had quite a bit of thickness left on it (about 1-2cm). I thought that the guide pins might be stuck, but they weren't and they moved freely. I greased them up anyway and put it back on the car (new pads and rotors of course). The other side had more even wear. I'm a bit lost other than maybe there are other factors that cause the caliper to not slide correctly on the guide pins. Anybody have some light to shed on this matter?
    On another note, i'm glad my wife noticed something was wrong (I believe some would ignore this problem). It was on the caliper that doesn't have the sensor so there wouldn't be any instrument warning.
    1987 Porsche 944T, 2012 BMW 328xi e92, 2015 BMW 228i f22
    Baldwin, MD
    E91, E39, 997 911
    You could have a sticky caliper. This is not at all uncommon.
    2007 Carerra S
    2009 E91
    1990 Toyo PU - POS
    2000 E39/5
    1976 911
    Dec 2013
    Chicagoland area
    EXOTICS
    Since you confirm that the guide pins are not the problem,
    I would also suspect sticking calipers, just be sure this is not a symptom of another problem,
    Like corrosion due to lack of brake fluid flushes, otherwise the symptoms will continue to occur!
  1. Uneven Brake Pad Wear
    By will525i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-20-2010, 01:52 AM
  2. Uneven brake pad wear
    By joako in forum 1996 - 2003 (E39)
    Last Post: 10-17-2010, 08:23 PM
  3. Wildly Uneven Brake Pad Wear - Any Advice?
    By AMFTime in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-14-2008, 11:06 PM
  4. uneven brake pad wear
    By vego99 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 05-24-2005, 09:13 PM
  5. Uneven Brake pad wear
    By Byzanz in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 12-09-2003, 01:46 PM
