Results 1 to 25 of 34
Thread: For those who has m62b44 non tu.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Dear friends, just tried put m60 cam to m62 non tu engine. Result is immpressed. For sure 15-20hp increased. Plus, find 2 additional exhaust cam and put to intake. Additional power gain.
    e39 540i 6speed Supercharged,
    E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
    Jun 2017
    Kenosha, Wi
    99 540i
    None tu? Lost me there. Lol
    Sent from my A571VL using Tapatalk
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Quote Originally Posted by 99Bimmer540 View Post
    Some one with tu engine should try it. I have just rebuild my engine and do not want to be face with that again.
    Aug 2015
    Oconomowoc, Wisconsin
    01 750il, E38/9 Parts
    Quote Originally Posted by dovlet View Post
    I'm almost positive it won't work, TU engines have vanos which will screw it all up
    Sent from my Nexus 6P using Tapatalk
    --- 750il Maintenance/Restoration Thread --- E38/9 Parts Cars --- YouTube Channel ---
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Quote Originally Posted by ColtonBH View Post
    Perhaps won't.
    Jun 2017
    Kenosha, Wi
    99 540i
    Are you the one that said you are looking to get rid of a supercharger?
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Yeah, i said. But then when i calculated how much i spent for stage 1 & 2 i changed my mind.
    Jun 2017
    Kenosha, Wi
    99 540i
    I know if you know anybody looking to get rid of one or I can find some headers with v flange for turbos
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Can you please send some photos of headers for turbo v8
    Jun 2017
    Kenosha, Wi
    99 540i
    I have no photos, I am looking for some V flange headers myself. Photos would be nice.
    Jun 2017
    Kenosha, Wi
    99 540i
    I have asked this question a couple times, how much boost would a stock m62 handle?
    Feb 2014
    Caboolture, Q, Australia
    E39 535i
    Did you swap the M60 heads too or will the cam fit the M62 head?
    Absinthe makes the tart grow fonder
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Quote Originally Posted by StRaNgEdAyS View Post
    Yeah, it is fit. Minor changes should be done. Star should be grinded a bit or you should change your chain for duble chain.
    Apr 2016
    the great pacific n.w.
    540it, 540sedan, 540-6 s
    While this cam swap is a great addition to a m62, the cams cannot be used without swapping heads.
    Yes, major work could be done meaning making a two part clam shell spacer to weld together onto the front cam journal, then grinding the thrust surface for clearance and to not to tear up the head thrust surface.
    Then the blending of the dual chain cam and single main chain as the spacing is off.
    Best to swap m60 heads and then run the whole m60 double chain setup.
    Even wit the complete dual chain setup, the trigger wheel will need modifications.
    I have included a picture of a m60 cam on a tu head to show front cam journal width difference. 20171019_130926.jpg
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Quote Originally Posted by wagons ho View Post
    Yeah, you are right but, you can do that with no swamping the heads. Only cams, also it is better to switch it to double chain but a\lso you can do it with single chain, just need some grinding on cams stars (have no idea about right name but in Russian we calling it Звездочька)
    Aug 2015
    Sprocket? You're talking what the chain goes around, right?
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Right. The sprocket from m62 should be grinded a bit to fit m60 cams. If you change single chain set up to two cain then not thing to be changed.
    Feb 2014
    E39 535i
    You had no valve clearance issues with the piston in the non vanos engine due to the more aggressive cam profile?
    IIRC the pistons don't have cut outs like those on the vanos engines do
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Just to clarify...
    So you:
    Put M60 exhaust cam into -> M62TU exhaust cam position
    Put M60 exhaust cam into -> M62TU intake cam position
    Also - which engine is this? Did you have your engine re-sleeved already? Hard to keep up with whats happening in Ashgabat.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Just to clarify...
    So you:
    Hahaha,
    No bro, that is not m62tu. We are talking about m62 with m60 cams. Some one said it is possible to put in to m62tu as well. But, i do not know.
    I know only that it is giving good result if m60 cams will be installed in to m62. There a re way as i described little above.
    Nov 2011
    Mel, Aus
    5series M62B44
    My brain hurts.
    Quote Originally Posted by hakhawk
    I know first hand that owning a bmw isnt what made hozy the way he is, its just his charm
    HoZY is good guy and has proven it many times by being a longtime participant in this community.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Quote Originally Posted by HoZy View Post
    My brain hurts.
    What is happen with your brain?
    My brain hurts.
    Sep 2015
    Mankato, MN
    1999 540i
    Mine is seeing double.
    Feb 2014
    E39 535i
    What he's done is put M60B40 cams into M62B44 heads, machined off one of the sprockets rows on the cam gears to accommodate the single row timing chain, and evidently has good results.
    Apr 2016
    No. Refer to my previous post.
    I'll give credit for the good results part as increased cam specs will raise performance. But this is not a bolt on swap .
    Remember that silly little issue of cam journal width?
    Until someone tells me how they overcame it I will beat the drum and say you must change heads.
    Misinformation is a disservice.
    And you don't machine off a row of the double sprocket, you machine down the backside of the m62 main chain transfer gear.
    And I'm not worried about piston to valve clearance as the 4.0 has the same deck height, but what about valve spring/ seal clearance on 5he m62 head?
    Remember, I'm for it but trying to help.
  1. For those who has/have manual tranny...
    By ganzibye in forum 1996 - 2003 (E39)
    Last Post: 10-26-2010, 06:55 PM
  2. For those who has problem with picking wheels
    By Kali 325 in forum 1991 - 1999 (E36)
    Last Post: 05-15-2007, 06:53 PM
  3. Question for those who installed front center armrest
    By vroo//M in forum 1991 - 1999 (E36)
    Last Post: 03-16-2001, 09:32 AM
  4. Question for those who installed their own front center armrest
    By vroo//M in forum 1992 - 1999 M3 (E36)
    Last Post: 03-15-2001, 04:35 PM
  5. For those who answered the BMW ACT questions I posted last month...
    By BMWguy206 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-04-2001, 10:49 PM
