Results 1 to 4 of 4
Thread: Iacv install question
    Jun 2005
    DALLAS
    325IS
    When installing the Idle Air Control Valve, which way is the arrow on the valve supposed to face? Upward facing the manifold or downward? I installed it with the arrow facing upward I believe, and now when I start the car, the RPM's are sky high. I also installed a new throttle cable and accelerator pedal bushings and did adjust the cable so that the throttle plate is all the way open when the pedal is pushed all the way in. Something is making the rpms be too high and then the needle just stays, it does not come back to idle rpms( say around 750). Something is stuck.
    I was thinking it is the idle control valve but it could also be the throttle plate?
    At least the car is starting now. Went to dealer and got a new fuel pump relay and it started. Also, having a new battery made a difference.
    Pelican Parts's Avatar
    Pelican Parts is offline Senior Member Supporting Vendor
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Hello - the arrow on top of the ICV. It is supposed to point towards the block.
    888.280.7799 | 6am - 5pm PST
    Jun 2010
    NY
    1997 328i
    You have it correct, it points up towards the manifold (down towards the block is incorrect).
    Your throttle cable is probably holding open, so you gotta do some adjusting.
    Jul 2003
    Spring, TX
    E36 328is, E39 M5
    Adjust the throttle cable to close the butterfly valve... that'll bring the rpms down.. had to do the same to mine after replacing the cable.
    Lime Rock Park... the most fun you can have in a mile and a half.
  1. Strut Brace install question
    By e36driver in forum 1992 - 1999 M3 (E36)
    Last Post: 08-23-2010, 11:21 PM
  2. Aftermarket Stereo Head Unit Install Question
    By BumbleZ in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-28-2001, 09:01 PM
  3. Intake install question
    By og325 in forum 1991 - 1999 (E36)
    Last Post: 05-22-2001, 08:38 AM
  4. X-brace install question
    By Stylin in forum 1992 - 1999 M3 (E36)
    Last Post: 03-16-2001, 11:11 PM
  5. Suspension Install Questions...
    By joeyc in forum 1991 - 1999 (E36)
    Last Post: 03-08-2001, 11:50 PM
