BMW of Bloomfield
Results 1 to 2 of 2
Thread: 1970 BMW 2800 CS - Turbo'd M30B35 3.5L 450rwhp - 5 Speed Manual - Rust Free Chassis
    Nov 2007
    Austin, TX
    2003 540i6 M Tech
    1970 BMW 2800 CS - E9 Chassis
    Engine: 3.5L turbocharged I6 @ 450rwhp
    Transmission: 5 speed manual
    Title: Clean CA, in hand
    VIN: 2280211
    (Note:​ I'm helping a friend sell this but I've personally seen the car in San Diego and this thing is a beast. Solid power delivery, body is in amazing shape and the cage design eliminates all the flex these cars normally have yet it somehow rides better than my E39 ��.)
    It goes without saying this is a one of a kind BMW E9. Restoration alone took more than one year. If you price out a duplication of this car you will find the total is significantly higher than my the price. This car has been well cared for and I know I’ll regret this the minute it drives away but I simply need to free up capital for a business expansion.
    Rust is a serious issue for all E9s but this one is solid. All suspension points including shock mounts are 100% rust free. When the car was restored the passenger front floor pan was the only area needing repair and it was simply removed and replaced with a new panel. The strut towers (a common rot point) are in good shape as shown in the pictures. The only rust worth mentioning is minor bubbles on the underside cowl area of the hood (see pictures).
    Engine / Drivetrain:
    • Turbocharged M30B35 3.5L I6 engine built by Paul Burke while owned by Jesse OÂ’Hara of Pure Turbos (Oceanside, CA) @ 450rwhp
    • Engine build included custom ground camshaft, five angle valve job, new valves / rocker arms and is running OEM forged pistons, rods and crankshaft
    • Custom turbo kit centered around a billet 6766 T4 turbo (67mm, .81 AR) running 13psi through a billet front mount intercooler
    • Getrag 265 5 speed manual transmission (no grinding, pop outs or slipping)
    • 3.60 limited slip rear differential
    • Megasquirt II engine management system
    • Custom fuel cell and filtration system
    Roll Cage:
    • Professionally built by The Truck Shop in Miramar, CA
    • Meets SCCA / NASA build specifications only requiring door bars to compete in wheel to wheel racing
    • Primary tubes are 1.75” x .120” DOM
    • Secondary tubes are 1.50” x .095” DOM
    • Cage was dropped through the floor pan so all welds are 360* (see pictures)
    • Dimple die reinforcements tying the front down tubes and main hoop to the A and B pillars
    • Tubular seat mounting frame running above the floor pan
    • Rear halo / crash bar protecting fuel cell, battery and wiring
    Chassis:
    • Bilstein coilers (adjustable)
    • Adjustable sway bars (ST)
    • Four wheel disk brake conversion
    • Custom 3 piece Jongbloed racing wheels (staggered)
    • Yokohoma S Drive tires (255/40R17 rear, 235/40R17 front)
    • Shock towers reinforced with .120” plates tied into roll cage
    • Differential mounts reinforced with .120” plates tied into roll cage, triangulated to prevent fore/aft and left/right movement under acceleration
    • Custom rear bulkhead
    Exterior:
    • Exterior professionally repainted in the factory color
    • Any blemished trim has been replaced
    • CSL front bumper custom flush mount
    • CSL rear spoiler wrapped in matte black
    Interior:
    • SFI approved G-Force Racing harnesses
    • AEM UEGO wideband hidden behind dash panel for AFR monitoring
    • Alcantara headliner
    • Bespoke carpeted flooring custom made after cage installation
    • Refurbished vinyl dashboard
    Misc:
    • Lots of spares included with the car. Rear seats, switches, glass, trim etc. Approximately one full truck bed of spares worth a few thousand.
    I’m asking $65,000 or best offer, cash or cashiers check only. I will gladly take any prospective buyers for a ride but I do require proof of sufficient funds before letting anyone drive this car due to the value and rarity. Out of state buyers will be responsible for transport but I can recommend a broker should the need arise.
    Feel free to PM me with any questions or to schedule a showing.
    Thanks for looking!
    Nov 2007
    Austin, TX
    2003 540i6 M Tech
  1. 1970-71 BMW 2800 CS Super clean-not cheap - No Longer Available
    By Peter Coomarasw in forum Non Specific BMWs (Classics, Exotics, MINIs)
    Last Post: 09-28-2016, 04:27 PM
  2. 1970 BMW 2800 Sedan - No Longer Available
    By BrianKrytenberg in forum BMW Cars For Sale / Wanted
    Last Post: 03-28-2016, 04:29 PM
  3. Replies: 2
    Last Post: 03-07-2016, 01:07 AM
  4. Fs - 1971 bmw 2800 cs e9
    By ibchumpy in forum Non Specific BMWs (Classics, Exotics, MINIs)
    Last Post: 03-04-2013, 03:09 PM
  5. F/s 1970 bmw 2800 cs
    By SilverstoneCars in forum Non Specific BMWs (Classics, Exotics, MINIs)
    Last Post: 06-03-2012, 08:25 PM
