Results 1 to 9 of 9
Thread: dynamic stability control .......
    Mar 2017
    Norwich, Connecticut.
    E46 wag. E36 convertible
    I have a LOT of thump and thunk in my drivetrain upon daily travels. My 03 three wagon has the optional "DSC" system...It is the shadow image of GM's Cadillac "Stabilitrak" automatic transmission-suspension...recoil to instabil road conditions.
    Upon the delivery of BMW 'DSC' is 'drive shaft breaking' an element (computerized) employed before human foot breaking. The transmission is a key player...for DSC.
    Has anyone any input here?
    We have a button to deactivate DSC....and when I deactivate...my car no longer has heavy transmission thunks...and runs smooth with DSC disengaged... comments?...NOTE all BMW cars with DSC start with the ignition switch..all are ON...unless you disable.....with the switch located next to the seat warmers below the Business CD.
    Pelican Parts's Avatar
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Hello - I'm not quite understanding what you're asking here. The DSC has to do with the prevention of skidding - it improves a vehicle's stability by detecting and reducing loss of traction.
    888.280.7799 | 6am - 5pm PST
    Jan 2016
    Ca
    2001 525it
    Exactly what I thought after trying to read it
    Los Gatos CA
    1987 325is, e34, Z3, e39
    If the DSC system is falsely triggering (perhaps from wheel sensors that need to be cleaned of metal shavings) the reduction in engine power might be causing a bad flex disk or driveshaft center support bearing to clunk?
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    DSC uses wheel speed sensors, steering angle sensor, yaw sensor, throttle sensor, and a brake pedal sensor to control slippage of each wheel or correct oversteer. This is achieved by the ABS module controlling tire slippage by applying pressure to the slipping wheel's brake caliper individually and reduce throttle input. You could be having some DSC interference with your vehicles operation but the transmission has zero to do with the DSC system.
    Los Gatos CA
    The DSC system can also reduce engine output power, and uses that control in preference to braking when feasible.
    CAN bus was used sparingly in the e46 because it was still expensive back then. The DSC communicates with the engine ECU over CAN bus specifically so that it has reliable, low-latency communication to reduce engine output power.
    A thunk coming from the transmission area is probably the flex disk, which is easy to inspect. A clunk from the middle of the transmission tunnel is the center support bearing, which is hidden. The flex disk can fail on its own. The CSB usually fails because some other failing part puts stress on it. The drive shaft joints should be checked when the CSB is replaced.
    In this case I suspect the flex disk. If it's not replaced soon after it goes bad, then the CSB will fail. If a bad CSB is not replaced quickly, the CSB mounts on the body will be destroyed. Then repairs will be.. expensive.
    Dec 2013
    Chicagoland area
    EXOTICS
    My question is; have you scanned for errors, specifically within the DSC system, with a BMW specific scan tool/software?
    Also, are you running on tires with similar diameters?
    Aug 2014
    Lawrence Kansas
    Diff diameter tires would destroy the transfer case as well.
    Mar 2017
    The Michelin tires furnished before the boat trip..are! I bought a 'time capsule' .....
  1. n00b question #313: Dynamic Stability Control
    By eufo in forum 1996 - 2003 (E39)
    Last Post: 01-14-2008, 01:45 AM
  2. DSC??? Dynamic Stability Control
    By BeeMW740 in forum 1995 - 2001 (E38)
    Last Post: 08-18-2007, 05:40 PM
  3. Replies: 5
    Last Post: 07-17-2005, 09:31 PM
  4. question about dynamic stability control
    By hal88 in forum 1999 - 2006 (E46)
    Last Post: 05-14-2005, 12:52 PM
  5. Limited slip diff Vs. Dynamic Stability control
    By 95m3sc in forum 1982 - 1988 (E28)
    Last Post: 04-02-2003, 11:06 PM
