Results 1 to 7 of 7
Thread: Car shaking when speeding over 80 or braking
    Sep 2013
    Modesto CA
    08 335i e92, e39 touring
    My 335i e92 vibrates when I am going over 80 and also tends to vibrate when I press on the brake. Any ideas what could be? I have hear of brake calipers/ brake pad issues but how do I troubleshoot it. Thanks
    Aug 2017
    Sacramento
    2011 e90 335i
    It could be that your tires aren't well balanced. You could take it to a shop and prob charge like 20$ just to check. Or also when you brake, your rotors may not be smooth. You may need new rotors or just resurface them.
    Jan 2016
    Ca
    2001 525it
    Braking vibration is caused by warped brake rotors, have you replaced the brakes at some point and were they factory or after market parts? If they are aftermarket parts there's your problem.
    Nov 2013
    Portland, Oregon
    2011 BMW 328xi sedan 6MT
    Depending on miles it also can be the stupid hydro-mount on the tension strut, if one of those fails it feels exactly the same as a warped rotor.
    Dec 2012
    North Carolina
    2009 335i M-Sport Coupe
    Check your control arm bushings first. They are oil filled, so leaks indicate a failed bushing. Like Butanmist said, failed control arm bushings do feel exactly like a warped rotor. Warped rotors are fairly uncommon on these cars.
    Lift up the car and spin the front wheels by hand, if you feel excessive or uneven drag on the wheel, check brakes and rotors.
    Dec 2010
    eastvale, ca, usa
    '08 E92/'07 E90/'99 E36
    I replaced both tension strut and wishbone, now streering wheel vibration is completely gone under braking.
    Oct 2018
    Hamilton, Waikato, NZ
    2008 E70 X5, 2005 E90
    Same thing happened on my E70 X5 due to one of the ignition coils failed. Something to do with piston timing from memory. You get this juddering effect around 60-80+kmph. Check your coils, likely one has failed and needs replacing.
  1. car sliding when going over pothole or manhole cover
    By Harpz in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 02-07-2016, 10:49 AM
  2. Car Shakes When Braking at High Speeds
    By x13alle12x in forum 1996 - 2003 (E39)
    Last Post: 03-23-2010, 05:01 PM
  3. MY sterring wheels shakes when i press on the brakes at high speeds
    By kpipalldaway2 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-05-2007, 06:30 PM
  4. car shakes when braking...no solution in search
    By djbeatz08 in forum 1991 - 1999 (E36)
    Last Post: 10-20-2006, 04:19 PM
  5. car shakes when braking over 100kms
    By freeze in forum 1991 - 1999 (E36)
    Last Post: 11-25-2003, 09:21 PM
