Bavarian Soundwerks
Results 1 to 4 of 4
Thread: What is this in my trunk?
    Feb 2001
    So Cal
    1997 M3 Sedan
    I removed the HK amp from my E36 and in that same area I found what looks like a plug that is not connected to anything. Anyone know what this is? (last photo is upside down)
    97 Estoril/Black M3/4/5
    "Although we've experienced an M3 sedan with an automatic, our test car came fitted as God intended, with a 5-speed manual ..."
    Road & Track May 1997, testing the M3 Sedan
    Apr 2016
    Philadelphia
    1997 m3
    Crap I forgot what it’s called but that’s normal. Those wires are all grounds. Every e36 has that.
    The Netherlands
    DE-spec E36 328i/M3 cab
    It's called a comb connector and is where various wires of the same color are spliced together. These are all over the car (and the whole fusebox under the top layer is full of these) and is what you use when properly retrofitting stuff. Aka not splicing in existing wires, cutting, hacking, sawing.
    You just find the comb connector with the color you need, and you take your new wire with a spade connector and simply slide it onto the comb. Sometimes all 'teeth' are taken. You can unplug all spades and insert a comb with more 'teeth'.
    This is how it looks without the insulator.
    IG:
    Feb 2001
    So Cal
    1997 M3 Sedan
    Great answer, thanks!
  1. what the heck is this in my trunk?
    By vdubpsu in forum 1983 - 1991 (E30)
    Last Post: 11-28-2009, 11:25 AM
  2. What is this in my paint?
    By dwf in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 07-06-2008, 10:41 AM
  3. What is this in my GloveBox ?
    By InSepsis in forum 1991 - 1999 (E36)
    Last Post: 05-05-2008, 09:22 AM
  4. what the hella is this in my trunk?
    By Wiestatv in forum 1991 - 1999 (E36)
    Last Post: 12-16-2007, 10:25 PM
  5. What is this in the trunk??? picture inside
    By skorpiond in forum 1992 - 1999 M3 (E36)
    Last Post: 11-15-2004, 01:47 PM
