Results 1 to 5 of 5
Thread: E36 M54B40 swap (rev limit problem)
    Feb 2016
    TH
    1993 bmw e36
    E36 M54B30 swap (rev limit problem)
    Hi, I have E36 m54b30swsp with ms43, but the engine rev is limited to 5500 , where is the problem?
    But sometimes specially when engine is cold it can rev higher
    Thanks in advance
    Jul 2004
    Houston, TX
    36 Cylinders
    You're missing vehicle speed signal to DME, so it goes into diag mode. Or any other missing signal. Very common of these swaps.
    You need a proper tune. Very easy to fix if you know what you're doing.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Feb 2016
    TH
    1993 bmw e36
    Thanks, its my first, sorry, but can i fix it without ecu tuning?
    Jul 2004
    Houston, TX
    36 Cylinders
    You don't have to be sorry (I hope you didn't take it as me being offensive).
    I don't think you can easily fix it without tuning. But the tuning isn't too hard. That was my point. If you pull the partial flash from the MS43, I'll do it for you.
    -Abel
    Feb 2016
    TH
    1993 bmw e36
    Thanks, very helpful
  1. 1994 E34 530i RPM Rev limiter problem!!
    By JayBMW5 in forum 1988 - 1996 (E34)
    Last Post: 09-03-2014, 01:22 PM
  2. M52 Rev limiter problem
    By philip77o in forum 1991 - 1999 (E36)
    Last Post: 10-10-2013, 03:44 AM
  3. Auto-to-Manual Swap | rev limite @ 4000 !!
    By MAD 325I in forum 1992 - 1999 M3 (E36)
    Last Post: 01-11-2011, 08:44 PM
  4. Conforti E36 M3 Software: rev limit behavior
    By Dinanify in forum 1992 - 1999 M3 (E36)
    Last Post: 07-03-2006, 10:02 AM
  5. speed and rev limit problems with chip
    By AKCraig85 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-23-2004, 09:18 AM
